HEY IB: Requests
superuser
Re: HEY IB: Requests
Punch the dot
Administrator
I can think of two votes right off the bat, bigger avatars (140/70 pixels is small by forum status). And we have always liked the idea of different colored patron names. You want us to pay the 5 bucks a month again (mine hasn't run out from when you did not own it)... then indulge us a little if you will.
The userinfo breadcrumb takes up enough space as it is, which is why patrons only get larger (in width) + animated avatars and that there's no easy way without a bunch of hacking to let users have individual colored usernames (you guys couldn't pick a new color last time it was suggested to change).
Personally I hope they could just fix the performance issues, but I have little faith at this point
__________________
Got a 1995-1996 240SX? Want a new front bumper?
Check this out. Posting on drag first to try and avoid shipping it.
Administrator
Short of a completely different system being implemented (i.e. not just a rep reset), that's not happening.
__________________
I like grape drank
That is the thing though. Space should not be an issue for them at this point. They have TONS of server space I'm sure, and can do with a little show of faith.
Administrator
Server space has nothing to do with it, I meant visual space, i.e. the room the userinfo block takes up on a page. Look at your post for example, currently it takes up about as much space as the post itself you made. Probably ~50% of the page is "useless" information. I don't want to make it any higher by allowing avatars with greater height. I'm just glad there's a way to make it signatures only appear once per page per user.
__________________
141.12 kHz
I like grape drank
Ok I understand a bit better, so a more simple page. Gotcha.
But then just make it so the join date and all that stuff shows up once a page, like the sigs do or something similar. Just condensed I guess.
I mean, its not just a request for them to do things, its really just...
They are being dicks, quit it.
