k series parts
k series parts
Means of contact: 7572327569
Price: $ obo
Description: k20a3 parts
Head ... Bare
16 valves and springs
Cams and gears
2 valve covers
Block
Crank
Pistons and rods
Oil pan
oil pump
Water pump
Alternator
Wire harness
Charge harness
Coil packs... 2 sets
K20a2 parts
Cams and gears
15 valves and springs
Rocker assembly
3 pistons and rods
Oil pump
Intake manifold
Pictures:
ILOVEPENIS -- If this line is still here it means you probably didn't fill out the required information correctly and a mod will be locking your thread shortly. You should probably delete it.
Price: $ obo
Head ... Bare
Cams and gears
2 valve covers
Block
Crank
Pistons and rods
Oil pan
oil pump
Water pump
Alternator
Wire harness
Charge harness
K20a2 parts
Cams and gears
Rocker assembly
3 pistons and rods
Oil pump
Intake manifold
Pictures:
