k series parts
Location: chesaprake Means of contact: 7572327569 Price: $ obo Description: k20a3 parts Head ... Bare 16 valves and springs Cams and gears 2 valve covers Block Crank Pistons and rods Oil pan oil pump Water pump Alternator Wire harness Charge harness Coil packs... 2 sets K20a2 parts Cams and gears 15 valves and springs Rocker assembly 3 pistons and rods Oil pump Intake manifold Pictures: ILOVEPENIS -- If this line is still here it means you probably didn't fill out the required information correctly and a mod will be locking your thread shortly. You should probably delete it. |
