Fresh b18b LS Swap w/ jdm gsr lsd trans and JDM GSR long block for ?????
Zip: 21222
Contact- CODY - shoot me a pm
Willing to meet or you can pick up or ill deliver
Have plenty of Vouches
SWAP
b18b1 ls swap ( currently in md DD )
-came out of a wrecked 95 acura ls special edition with almost 90k on it.
-motor just had timing belt, waterpump, oil pump and head gasket. full complete service. the motor runs excellent! also has a brand new distributor on it along with new valve cover gasket new tb gasket new exhaust manifold gasket.
-motor is bone stock it has a b20 valve cover on it.and it has a bdl cam seal. also has a gsr tb. car is tuned on s300 and runs great.- im keeping s300!
-jdm gsr trans w/lsd 50 k tops. trans is butter. fresh axle seals and trans fluid.
-act 6 puck unsprung clutch heavy duty pp. fresh resurfaced flywheel.
-can include a stock header or aftermarket one thats on there for extra
-can come with a stock ecu.
-wont come with axles but with halfshaft (axles will go if i go another route n cant use them)
-will come with stock mounts or aftermarket innovatives
-have gsr linkage for eg bseries
( also have arp head studs , a golden eagle lsvtec kit for an ls vtec swap. both brand new - can go with using the gsr head below on this motor. only thing needed is a headgasket )
----car runs great never had any problems. no knocking or an wierd noises. car starts right away and runs all day long. oil changed every 3k. trans fluid changed every 10k. ask any of my vouches motor is clean and runs great. car made good torque and with the lsd and the short trans the car is quick. can see the motor run but the car just got taken off the road. due to being a project car.
800$ cash takes the longblock
1700$ takes the full swap (taking offers and trades on other setups, price is the way it is because of the trans. and the 500$ worth of service done to it 5k miles ago.)
Looking to trade for whatever you have- Bseries Vtec boost or allmotor ( Built Gsr, LsVTEC, B16 or possible h22 )
i will work out any kind of deal everything listed above n below or some of it. looking to get a new setup. everything below is legit. its pretty much a full swap and a jdm gsr longblock for and lsvtec motor or another setup. too lazy to collect/order parts n do on my own.
Engine parts
1.--jdm gsr vtec head--- came with my complete jdm gsr swap i bought last year from ana trade. i put the complete stock swap in my car for about 3 months then pulled it to go boost. now deciding to go another route. i used it for maybe 10k. miles. head is in perfect working condition. it has everything but no intake mani and TB. has fuel rail. the head is complete. vtec solenoid distr. jdm gsr cams but no cam gears. and the v.c is shaved and moon cut
UPDATE: possibly getting a golden eagle manifold for a gsr head in a trade so this could get thrown in the deal as well
LOOKING to trade for a BUILT bseries head. b16/gsr/type r with valvetrain and maybe work done. i have cash on my end.
this is perfect for someone looking to go back to stock or looking to change there set up.
Price for the head outright is 500$ obo
2.--jdm gsr block-- block is from the swap above. was guna get it sleeved now im just guna do lsvtec. complete block with no pistons or rods. sold them to buy aftermarket ones for boost. block is clean! and has been partially honed. crank was checed and is fine. bottomn end is loosely thrown back together but with no crank but has everything there.
LOOKING to trade for complete ls bottomn end. plus cash or if its built for all motor ill throw in cash.
this block is in great shape
price for block outright is 500$ obo
-also have brand new acl rod and main bearings i could throw in. also a bottomn end gasket kit. i could throw all in for a lil extra
bump if you view please
Zip: 21222
SWAP
Engine parts
simplsi
Engine / Exhaust / Drivetrain
11
02-27-2009 11:26 AM
