BUILT B18C1 LONGBLOCK - JUN - PCT - ARP - SKUNK2 - PERFORMANCE PRODUCTS CHEAP!
Means of contact: 804-305-8378
Price: $1000 Will take a reasonable offer, Like I said trying to get my coupe back together. Thanks. Text for pictures. Ive got other parts Ill throw in based on price, such as :
3" intake with velocity stack
hytec header
chipped p28 with map street tuned for this
competition clutch kit
b16 transmission
innovative mounts
Description:
Just had the engine rebuilt, Davis Machine shop in Richmond did all the work from machining to assembly. Has less then 1000 miles, Im putting a stock ls engine in my GSR and selling this to finish my coupe. Have pictures upon request, detailed list of parts and specs below. Thanks.
B18c1 bottom end
81.5mm bore and hone
PCT (CTR Pistons)
new rings
acl bearings
ls rods
ls crank
arp rod bolts
arp headstuds
oem oil pan gasket
new oem seals and gaskets
new oil pump
new water pump
new timing belt
new tensioner
balanced and decked bottom as well. Just enough to freshen up
B18c1 matching head
Jun1 cam shafts
HKS cam gears
typer full valvetrain
viton valve seals
oem valve guides
new oem cam seals
new valve cover gasket kit
str cam seal
vtec solenoid
ngk blue wires
skunk2 pro series intake manifold
new injectors orings and seals
performance products 68mm tb
new intake manifold and tb gasket
purple painted valve cover
hytec header
b16 transmission
innovative mounts
Description:
B18c1 bottom end
PCT (CTR Pistons)
new rings
acl bearings
ls rods
ls crank
arp rod bolts
arp headstuds
oem oil pan gasket
new oil pump
new water pump
new timing belt
new tensioner
B18c1 matching head
Jun1 cam shafts
HKS cam gears
viton valve seals
oem valve guides
new oem cam seals
str cam seal
vtec solenoid
ngk blue wires
1lowaccord
Engine / Exhaust / Drivetrain
17
04-10-2012 04:47 AM
2litreGSR
11
01-02-2011 06:33 AM
LSD_Moe_Lester
44
02-23-2010 08:37 PM
