Motor cycle throttle bodies
I was wondering if what the size of honda cbr 929rr throttle body sizes are? I couldn't find anything online or I was looking for wrong thing.
Is there any motor cycle with quad 40-50mm throttle bodies?
I would love to find some for bike that the TB's are all seperate but are connected via rod or something.
Re: Motor cycle throttle bodies
i don't think you can change them, not that easily anyways... and if you did it would require lots of dyno time to get it dialed in... might want to check out some CBR forums, the only thing i could imagine is if the 954rr has a slightly bigger set or something you might be able to use those, because i know guys w/ 01-02 GSX-R 1000's put 2003 throttle bodies on them
Do some research... It has been done, you aren't a pioneer and the people had a huge budget! The best one was done on a Dodge Neon and was in I think superstreet. Either way, do some more research and you will find the people that have done it.
Later,
Sean C.
Later,
Sean C.
