How much potential does your car have?
Old Sep 20, 2007 | 12:24 PM
QwanSanchez's Avatar
Taking the shot
QwanSanchez is infamous around these partsQwanSanchez is infamous around these partsQwanSanchez is infamous around these partsQwanSanchez is infamous around these partsQwanSanchez is infamous around these partsQwanSanchez is infamous around these partsQwanSanchez is infamous around these partsQwanSanchez is infamous around these partsQwanSanchez is infamous around these partsQwanSanchez is infamous around these partsQwanSanchez is infamous around these parts
Default Re: How much potential does your car have?
Originally Posted by driveahonda
The car is designed with the power level in mind...
well i guess that would be a factor in how much potential your car has. If it was designed to have 150hp then it drastically limits the cars potential.
Old Sep 20, 2007 | 12:25 PM
JDM74's Avatar
JDM74 JDM74 JDM74 JDM74 JDM74 JDM74 JDM74 JDM74 JDM74 JDM74 JDM74
Originally Posted by QwanSanchez
heres another question i've been having how come you can put down 500hp in one car ( ex: Z06) and it seems like there are alot less issues with traction as oppose to if i was putting down 500hp in a mustang id have tons more issues with traction? Is it just a suspension issue? Car design?
Well you are comparing a car that was designed with 500 Hp to a car that was designed with a lot less. Of course the suspension design is going to be an issue as well as the car design.
Old Sep 20, 2007 | 12:29 PM
RobertE's Avatar
Function > Form
I have a '79 MG-B, of course it has its disadvantages compared to the Z06. Mostly aerodynamics at higher speed and traction. However it does have the advantage at weighing in at only ~2100lbs, thats with ac/heat/full interior/and the top on.. I would like to think that eventually with a turbo rover(cheap) or fully built n/a rover(expensive) it could easily take a z06, but of course that would be with a decent driver and alot of changes to help the frame take that power.
CavemanRacing's Avatar
www.CM-R.net
CavemanRacing CavemanRacing CavemanRacing CavemanRacing CavemanRacing CavemanRacing CavemanRacing CavemanRacing CavemanRacing
But that doesn't really have to do with the cars potential. That is a different question I guess. "What is the limit your car can do using it's FACTORY configuration?"
What I am saying is, you can change the aero, the suspension, the wheels/tires, etc, etc, etc. That alters potential greatly.
Taking the shot
True so like I said above I guess when trying to figure out just how far you can go with your car you have to take into account the design of the car. Although i'm sure there must be some cars out there that were designed for much less performance but by sheer dumb luck they are capable for much more.
Old Sep 20, 2007 | 12:33 PM
Iceman05's Avatar
I <3 BOOST
Iceman05 is an unknown quantity at this point
another couple hundred in tuning will get me over 400whp in my SOHC civic.... mid-low 11s....
(this after about 10k in mods over the last 4 years)
Old Sep 20, 2007 | 12:34 PM
Taking the shot
Well i guess you could see it as a different question but it is closely tied in with the original. My orginal question is what is the potential of your car? It could mean factory or as far modified as a tubular chassis. I guess the real question is when does the car stop being that car and turns into a straight up race car you know? I dont consider the race car versions of factory cars to "really" be those cars. I mean think about it the NHRA have fiberglass rearwheel drive version of the Toyota Solaris running 7 secs in the 1/4. Do you consider that car to really be a toyota solaris anymore?
Fobby's Avatar
Classified Moderator
Fobby Fobby Fobby Fobby Fobby Fobby Fobby Fobby Fobby Fobby Fobby
02 lexus gs300 with na-2jz with vvt-i ......2.5mm headgasket/800 to 1000cc injectors/ARP headstuds/turbo kit/fuel management easy 400hp to 700hp ....to bad auto tranny will not hold anything over 400hp....it could keep up with z06 ....hmm maybe
Old Sep 20, 2007 | 12:41 PM
www.CM-R.net
I don't consider it to be a "solora" any more than you do. That is a purpose built 1/4 mile car.
I wasn't even thinking about "race" cars when I started typing, just assumed this convo would disregard that and kind of stick to "street" cars.
Old Sep 20, 2007 | 12:44 PM
Dirk Dickbutt's Avatar
Wanna taste?
Dirk Dickbutt Dirk Dickbutt Dirk Dickbutt Dirk Dickbutt Dirk Dickbutt Dirk Dickbutt Dirk Dickbutt Dirk Dickbutt Dirk Dickbutt Dirk Dickbutt Dirk Dickbutt
I have an LS1 so that is buttons of potential right there.
As for my other car, I am hoping to get it into the 11s. Not bad for a Bonneville.
