Detailers (or anyone with a powerwasher): Proper way to use soap tube?
I <3 My DSM
Re: Detailers (or anyone with a powerwasher): Proper way to use soap tube?
i worked at sears for like 5 years in lawn and garden.....i know those power washers VERY well...ok like stated in the manual, you have to put the pressure washer on low spray pressure when using the applicator tube (the clear tube) ....to use low pressure, you should have to just pull the end nozzle of the pressure washer, than it sprays using a much softer pressure. To resume after applying intended product, simlply push the end back down (its been a while since i worked there, so i could have the pull/push lever in junction with the low/high pressure reversed, but it will be obvious on which is which)
I <3 My DSM
I have a power washing business and i can tell you that u need the cleaning solutions that are specifically for power washers. regular soap mixtures are way too thick which is why you go through it so quickly. the power washer specific stuff is cheap anyway. i did a whole house with half a bottle.
