Need a machine shop to redrill my rotors. suggestions
Old Sep 29, 2005 | 09:37 AM
DeepFreeze's Avatar
DeepFreeze is an unknown quantity at this point
Default Re: Need a machine shop to redrill my rotors. suggestions
some advice. if you are going to do it yourself.
heat the rotors up as much as possible (within reason)
then drill the holes.
the problem with MAKING new holes in rotors, is, if the metal is cold, its more likely to create stress fractures and fissures in the material.
which can lead to a hidden crack, then sudden break in the rotor.
a good machine shop tech should know to do this.
Old Sep 29, 2005 | 09:46 AM
LoSt's Avatar
LoSt is an unknown quantity at this point
I had mine drilled at a shop in Norfolk before I moved here to NOVA... I can't remember the name though, my boss refered me. Shops are out there, sorry I can't exactly say which one. I wanna say AJ's but I'm not sure
Old Sep 29, 2005 | 12:11 PM
Voodoo ST's Avatar
Handling is Key!
Voodoo ST is infamous around these partsVoodoo ST is infamous around these partsVoodoo ST is infamous around these partsVoodoo ST is infamous around these partsVoodoo ST is infamous around these partsVoodoo ST is infamous around these partsVoodoo ST is infamous around these partsVoodoo ST is infamous around these partsVoodoo ST is infamous around these partsVoodoo ST is infamous around these partsVoodoo ST is infamous around these parts
L&W machine in Norfolk will do it for you
GaRn
Jun 3, 2008 06:54 PM
yokojzz30
Jul 5, 2005 07:28 PM
Enigma
Oct 19, 2004 02:00 PM
