Honda crank pulley tool
Old Nov 7, 2008 | 12:49 PM
  #31
ryanherington's Avatar
yaaat.
Default Re: Honda crank pulley tool
I tried using the screwdriver and there's no holes to stick in the flywheel.
Old Nov 7, 2008 | 01:01 PM
  #32
CivicRenModelX's Avatar
CRX
CivicRenModelX has disabled reputation
I can try and help you sunday if you want dude? PM me.
Old Nov 7, 2008 | 01:25 PM
  #33
madsteez's Avatar
Ohhh Snap
madsteez madsteez madsteez madsteez madsteez madsteez madsteez madsteez madsteez madsteez madsteez
Your flywheel is prolly aftermarket.
Put the car in gear usually 4th works fine,put blocks in front and behind both of the front wheels. If the drivers front wheel is off stick a screwdriver through the caliper into the rotor so it can not rotate. That will keep the crank from moving.
Do not stick a ratchet on the bolt and try to crank the car,the crank rotates clockwise so you will just tighten the bolt even more.
Also spray the shit out of it with PB blaster,if theres corrosion around the edges and you dont spray it,then there is no way in hell your breaking the bolt loose.
Old Nov 7, 2008 | 02:31 PM
  #34
yaaat.
Got it. And the flywheel's not stock, Jared.
Old Nov 7, 2008 | 03:17 PM
  #35
Vanilla Face's Avatar
face is vanilla
I shot your car and still owe you the photos?
no?
Flite
Feb 19, 2009 06:18 PM
jmurgsr98
Want to Buy / Trade ARCHIVE
Sep 12, 2008 04:34 PM
sh!ttyLS
Feb 24, 2008 02:39 PM
