Gas?
Originally Posted by DarkUserX
Are you racist, you need to calm the fuck down man, you act like your a racing god... did you not get the attention you needed as a child? also what if i was black, would that affect anything... if you think so i have many a black friends that would like to introduce their fist to your face, i can setup the arrangement whenever just leme know
EDITED AGAIN btw im just going by what ive seen. and yes airplane gas is just higher octane, it'll work better than pump
well, my boss says he has used airplane gas before... he could be a lying bastard but in no way does that make me an idiot. is all people do on this forum is point fingers and put people down.... that'll get you plenty of friends in the real world.
FUCKING IDIOT!!!!!
Originally Posted by The_rabbit1
and tell your boss he's a flippin moron cause the antifreezing agent alone wouldn't burn, much less the diesel like actual fuel that ignites w/ a 24,000volt spark.
damn noobs where are they coming from
that's how drag is u can't take everything so seriously on here and have to grow a thicker skin (especially on touchy subject such as race and politics). Just trying to help you new bastards out
personally i really dont give a damn anymore, ooo im a noob thread should be closed now seeings how the subject got blown way off topic due to a not so noob member
It's all technicalities .
If your car's gear range is too wide , you will in fact not go as fast with a full tank . ex. if your car bogs down in top gear now before hitting the rev limiter or speed limiter , then a full tank will hinder you . But if you fall into this catagory , then your car is a 78 Pinto or a Yugo .
Also , if you have a fuel cooled in tank pump , then a low tank will make it run hotter with the possibility of slowing the pump and not supplying enough gas . A pump usually supplies enough PSI to keep the injectors at full capacity , but if you run your tank too low too often , then damage will occur and you will have problems at low fuel levels ( common Chrysler problem ) so a full tank will give the illusion of running faster .
