Will tune for food
Old Nov 14, 2006 | 12:36 PM
GaRn's Avatar
Default Re: Will tune for food
Originally Posted by Heiss M3
Awsome,
I've got an AccessPORT, do you know how to work with maps on those?
There are several free full featured dataloggers and I have the cable to reflash, the tuning/flash software is free too!
Gotta love it
www.openecu.org
Old Nov 14, 2006 | 12:48 PM
Nismortare's Avatar
Nismortare is an unknown quantity at this point
Originally Posted by GaRn
Hey, yes I have, I usually don't remove the layer of protective flux.
I use a desoldering bulb or wick..
If you find a write up on your specific application and everything I will do it for ya..
Getting to it isn't hard - it's the actual desoldering of the stock EPROM and soldering of a socket that I'm hesitant to try. I can pull the ECU box and pop in the new EPROM to the socket with no problem. If we could meet up some weekend, that'd be cool. Maybe after Thxgvg?
Old Nov 14, 2006 | 12:58 PM
GaRn's Avatar
Yea it shouldnt take long at all then just guessing..
After thanksgiving is fine, I can give you directions to my house if you want to do that.
Old Nov 14, 2006 | 02:19 PM
BSeriesTurbo's Avatar
Go Team Marlboro
BSeriesTurbo BSeriesTurbo BSeriesTurbo BSeriesTurbo BSeriesTurbo BSeriesTurbo BSeriesTurbo BSeriesTurbo BSeriesTurbo BSeriesTurbo BSeriesTurbo
I can tune the evo's for you
Old Nov 15, 2006 | 04:54 AM
Nismortare's Avatar
Sounds good, GaRn! Just send me directions via PM or e-mail me at brian02max "at" yahoo.com.
Old Nov 15, 2006 | 02:30 PM
AMDxp2000's Avatar
It tilts
AMDxp2000 has disabled reputation
I have an SMD solder bench as well as re-work equipement for damaged boards etc......i also solider in sockets and chips......
Just letting yall know i got the gear
Old Nov 15, 2006 | 03:15 PM
TNGChris's Avatar
out of curiosity,are you guys tuning on a dyno,or street tuning starting with a stock basemap or an already established map from a car with similar mods?as far as i know,there are no AWD dynos anywhere around here(i think the Evo guys go to NJ?),and the dyno in Salem doesn't actually offer tuning as far as i know.i think that Marshall and his friends have access to or own a dyno,but they're the only ones i know of.
my point is,do ya'll think that you can set up a safe tune that reaches the car's full potential with just street tuning and limited experience?there are a number of very good tuners with dyno facilities within a reasonable drive of our area that are manufacturer trained,and have loads of experience on many different systems.
Chris
Old Nov 15, 2006 | 03:26 PM
GaRn's Avatar
Chris
I never understood why anyone would think dyno tuning is better than street tuning, other than for partial throttle tuning, only because it can speed the process up by using loading, or getting timing picture perfect. In my case, I didn't have a basemap to start with, I made mine from scratch in CROME, I did have the ignition map however..
I use a wideband and knock phones / check plugs for timing. What aspect of street tuning do you think would not be safe? My AFR curve from the dyno was as flat as anything I have seen, 11.5-11.6 all the way across just about. Timing was spot on.
Actually, I have my car tuned so well that I have disabled closed loop, I run in open loop all the time, and I datalog every once in a while to make sure everything is good, always around 15.2:1 anywhere from 19 inHg to 10inHg, then slightly more rich until around 13.1:1 at full throttle.. I get better gas mileage too.
Old Nov 19, 2006 | 02:00 PM
90_accord_22657's Avatar
90_accord_22657 has disabled reputation
a and r fab has an awd dyno its in winchester
Old Feb 16, 2007 | 01:19 PM
Boost Happy's Avatar
www.TeamDOHC.org
Boost Happy Boost Happy Boost Happy Boost Happy Boost Happy Boost Happy Boost Happy Boost Happy Boost Happy Boost Happy Boost Happy
434-546-7661 call me asap
