BASS
the more power the have, the louder. the more surface area (# of subs) you have, the louder. i'm pretty sure you can search around on the net. but check this beast out: http://www.mtxaudio.com/caraudio/pro...jackHammer.cfm
2 JL 13.5 W7 Subs using a 500/1 per coil (4 500/1's) make sure you use a headunit that puts out over 4 volts thru the preouts (kenwood, eclipse, alpine + PXAH701) Shitload of money, but that's the loudest and deepest bass I've ever heard. The setup we had was running off of Kenwood Excelon DDX8017 pushing 5 volts preout.
the general concensous from those "other" ppl that happen to be stuck at a stop light beside such a vehicle is a baseball bat. MUCH cheaper not to mention HIGHLY satisfying to those other ppl to remove said back window.
Get 2 Adire Audio Tumults or Brahmas. They will do they job.
The loudest subs that are reasonable in size are the RE XXX or AA Brahma/Tumult or of course JL W7's. The best warranty, quality and prices are Elemental Designs. Memphis also makes some big ass subs.
Busting the back glass out would be simple with these subs. AA did over 160 DB's with one Tumult.
just save some money and get a shitty sub and amp from Wal-Mart(no need to upgrade your front stage...hearing anything other than bass is for pussies),and pull up beside me at a stoplight.you may even get a wack in the head for free too!
while you're at Wal-Mart,don't forget to also pick up a can of primer to spray at least half the body panels on your car(bonus points for getting a tub of Bondo and performing some "body modz" to the car prior to primer),a set of spinner hubcaps,some sticks of neon,some NOS seat covers and floormats,and a recip saw to cut your springs and wack off your muffler...you'll then have everything you need for the Roanoke custom Honda package.
good luck
Chris
