The Twisties For all you cone killers and nazis. This includes Auto-X, Road Racing, and Drifting.
Autocross at VMP, Sun Sep 28
Old Sep 24, 2008 | 08:33 AM
Niburu's Avatar
Forcibly Repped
Niburu Niburu Niburu Niburu Niburu Niburu Niburu Niburu Niburu Niburu Niburu
Default Re: Autocross at VMP, Sun Sep 28
when you get a chance the Miata should be NASA-X F
ooooh 1st heat will be fun to watch with the battle of the silver FD's - stock twin turbo rotary vs LS2 swap
Old Sep 24, 2008 | 02:31 PM
blksylv's Avatar
Boost LeRoy
blksylv blksylv blksylv blksylv blksylv blksylv blksylv blksylv blksylv blksylv blksylv
hey, i was wondering if i show up the day of and if im not able to get a helmet will there be any to borrow at the event?
Old Sep 24, 2008 | 02:37 PM
getfast's Avatar
at the track today?
getfast getfast getfast getfast getfast getfast getfast getfast getfast getfast getfast
Absolutely, we have a bunch of loaner helmets available for drivers. They are open face M2000 or M2005 rated, mostly HJC and G-Force brands, in any color you want as long as it's black or orange. ;-)
Please leave your drivers license at the timing table as collateral before your runs, and return the helmet as soon as you are done in case someone in another heat needs to use it.
Thanks for asking,
Jon
Old Sep 24, 2008 | 02:40 PM
blksylv's Avatar
Boost LeRoy
kewl, thanx
Old Sep 24, 2008 | 05:57 PM
JJSpinALot's Avatar
NEO VVL N1 BITCHES
JJSpinALot JJSpinALot JJSpinALot JJSpinALot JJSpinALot JJSpinALot JJSpinALot JJSpinALot JJSpinALot JJSpinALot JJSpinALot
Originally Posted by FORZWIN
I tried to get you out a while back, where was your interest then?
Not sure I'll be there for this one, my driver-side window got smashed and I'm trying to get it all replaced in my free time.
Jon,
Can we get an all se-r 3rd heat? lol
you tryin to go to this? if we can get some se-r guys out there i will definatly go. if i go do this cone dodging thing with you you need to come to VIR with me in november.
and if you get the glass and bring it over ill put it in for you.
Old Sep 24, 2008 | 08:11 PM
FORZWIN's Avatar
FORZWIN has disabled reputation
I can't make it to this one, I'm in the midst of buying a house + getting married near the end of November and I fear my motorsports activities are about done for the year. I'd love to get out to VIR, Zach's been trying for a while but it's just bad timing this year.
I actually went to the jyard and picked up an entire door with new glass and all, so I filled the dents last weekend and am just waiting to paint it to match in my non-existent free time. Not sure if you remember, but I had that crazy axe slice in the side of it and it was causing a lot of rust inside the door. I do need to get with you and see if we can work something out on the windshield, mine is pretty beat.
Let me know if you make it out Sunday, I'll try to drop by.
Old Sep 24, 2008 | 08:52 PM
STI-roids's Avatar
STI-roids is an unknown quantity at this point
Hey all, I'm new to this. Everything that I did before was SCCA. How or where can I find out what class I should be in? Thanks in advance.
Old Sep 25, 2008 | 06:26 AM
getfast's Avatar
at the track today?
NASA autocross classing is a "base class plus points for modifications" system. That is, every car has a base class (in order from theoretical fastest to theoretical slowest: R, U, S, A, B, C, D, E, F, G.) Everything you modify on the car has a points value (for instance +3 for Konis, +5 for RA1s, etc.) Some things you can do to the car are "no points" mods (for instance camber plates, flywheel, bushings, short shifter, etc.) Every 20 points bumps you up a class (i.e. a D car with 0 to 19 points stays in D, a D car with 20 to 39 points bumps to C, a D car with 40 to 59 points bumps to B.)
Base classes and points penalties are listed here:
http://www.nasaproracing.com/rules/n...-X_Classes.pdf
Once you know your base class from there, you can use this worksheet to figure out the points and the final competition class your car will be in:
http://www.nasaproracing.com/rules/n..._ClassForm.pdf
You may also want to familiarize yourself with the NASA-X national rules:
http://www.nasaproracing.com/rules/n...SA-X_Rules.pdf
And the mid-atlantic regional NASA-X rules supplement:
http://www.get-fast.net/nasacross/na...supps_2008.pdf
Hope it helps,
Jon
Old Sep 25, 2008 | 12:02 PM
JJSpinALot's Avatar
NEO VVL N1 BITCHES
unsure how my engine swap will work out but I'm pretty sure I'm nxe. I need to sign up tonight.
Old Sep 25, 2008 | 07:40 PM
FORZWIN's Avatar
After talking to Jon, that's where he classed me (nx-e). I was fairly competitive despite my suspension and alignment. You should do well.
