Wtf Is Wrong With My Car?!?!?!?!?!?!?!?!?!?!?!
The valve lash should be re checked after rotating the crankshaft, if the clearance is not enough, your exhaust valves may not be closing, and you will loose compression. If the lash is to loose you may not achieve full lift. Check your compression and your lash again.
