Weird starting problem
Old Nov 16, 2004 | 06:13 PM
jackson's Avatar
jackson is an unknown quantity at this point
Default Weird starting problem
On my 91 civic dx hatch, every once in a while it is hard to start. I have to try about 5 times. when trying to start the car sort of "kicks". This happens about every other day now. Any idea what causes this?
Old Nov 16, 2004 | 06:27 PM
1sikcvc's Avatar
1sikcvc has disabled reputation
Default Re: Weird starting problem
original engine.
that's it. naw i'm playin.
it all depends. it could be a number of things such as: starter(but that wouldn't kick), fuel pump(but it probably wouldn't start at all then), plugs/wires(damn well, maybe but probably not). does the car run funny? tried a self-diagnostic? pm me and i can tell you how.
ps-just kinda wanted to make a smart comment but i really do wanna help so pm me.
Old Nov 17, 2004 | 03:40 AM
jackson's Avatar
Once it starts up it runs great. so I am not sure what is casing it
Old Nov 17, 2004 | 06:01 AM
ToyotaTechGeek's Avatar
brake/steer/throttle
main engine relay. kinda presents itself like a vapor lock problem
Old Dec 23, 2004 | 01:41 PM
civic1987's Avatar
civic1987 is an unknown quantity at this point
well u should look at ur battery cable, it may be loose because thats what happened to me
Old Dec 23, 2004 | 02:04 PM
00civichatch's Avatar
JAY SPEC
00civichatch 00civichatch
check the starter solenoid ground. if that dont work i got a ls full swap for $800
http://www.dragva.com/forums/showthread.php?t=75662
p.s. - its a dx who cares
Old Dec 23, 2004 | 02:45 PM
SlowLS's Avatar
Sumospeed #O.G.
Check to see if you ecu is throwing any code3s after you car is running for a while. IF so, it is probably an o2 sensor. My car did the same thing
Old Dec 23, 2004 | 02:46 PM
Main relay..
Old Dec 24, 2004 | 10:40 AM
EvolutionBoostin's Avatar
Currently N/A
EvolutionBoostin is an unknown quantity at this point
Main relay. Try hitting the panel that the relay is under and the car will start right up (while you're cranking it). The panel is next to the change dish to the left of the steering wheel. You will have to open the door.
It sounds ghetto, but it works lol. New relay was ridiculously expensive from hall honda so i resort to hitting mine to make my car start. This happens because the solder balls crack over time and the fuel pump doesn't cut on.
Old Dec 24, 2004 | 10:45 AM
The main relay can actually be reflowed, the solder joints get fatigued over time but all you need to do is take the relay apart enough to get to the circuit board. A good sized soldering iron is all it takes to reflow the solder joints, and you're good for a few more years. I've done it to a couple EFs with your exact symptoms.
