vtec problem!
Old Jan 20, 2012 | 04:24 PM
gingerbreadman's Avatar
gingerbreadman is infamous around these partsgingerbreadman is infamous around these partsgingerbreadman is infamous around these partsgingerbreadman is infamous around these partsgingerbreadman is infamous around these partsgingerbreadman is infamous around these partsgingerbreadman is infamous around these partsgingerbreadman is infamous around these partsgingerbreadman is infamous around these partsgingerbreadman is infamous around these partsgingerbreadman is infamous around these parts
Default vtec problem!
Ok heres the deal my vtec isnt engaging at all. i know its wired up right, but heres the thing my vtec is suppose to engage at 4500 rpm and when it reaches it the check light comes on. idk if the solenoid is acually bad or the oil pressure switch needs to be replaced. please help any advice will do.
Last edited by Fabrik8; Jan 20, 2012 at 07:52 PM. Reason: Removed mention of For Sale thread...
Old Jan 20, 2012 | 04:29 PM
E.Honda's Avatar
Reporting FS Threads
E.Honda E.Honda E.Honda E.Honda E.Honda E.Honda E.Honda E.Honda E.Honda E.Honda E.Honda
Default Re: vtec problem!
Car? Engine? OBD? All of these would be good things to include in your post. Also turn your rep on.
Old Jan 20, 2012 | 04:41 PM
changed oil today
Old Jan 20, 2012 | 04:42 PM
NasTHatch's Avatar
RIP DRAGVA-2016
Originally Posted by gingerbreadman
changed oil today
then check the ECU and make sure all the wiring is connected
Old Jan 20, 2012 | 04:45 PM
Odysseus Prime's Avatar
Previously Odyssey
Odysseus Prime Odysseus Prime Odysseus Prime Odysseus Prime Odysseus Prime Odysseus Prime Odysseus Prime Odysseus Prime Odysseus Prime Odysseus Prime Odysseus Prime
What ecu? Chipped?
Try another ECU if possible.
edit- what NasT said too. Post wasn't there when i replied.
Old Jan 20, 2012 | 04:46 PM
i know its wired right at one point the check light stayed all the time so i had a friend check the codes and it was the vtec so he found that the wires were cut somehow so he wired it back up and the code went away but when i try to go into vtec it comes back on until i turn it off and start it back up
Old Jan 20, 2012 | 04:51 PM
Previously Odyssey
sounds like same issue.
http://www.team-integra.net/forum/11...ipped-ecu.html
In case anyone else runs into this problem, here is what the problem was:
An incorrect transistor was installed on the ECU board. I purchased another ECU and returned the bad ECU.
Old Jan 20, 2012 | 05:06 PM
83Stang5.0's Avatar
Digital Life
I doubt he randomly has a certain year range ECU that doesn't work with a certain type transistor, that actually has said transistor installed.
Pull the code and see what the fuck it says, it sounds like the pressure switch since it only comes on when you go to cross over.
Old Jan 20, 2012 | 05:24 PM
Originally Posted by Odyssey
wow makes alot of sense thanks for the link man
Old Jan 20, 2012 | 05:51 PM
Previously Odyssey
Kind of confused by this lol.
It has nothing to do with the ecu, but the mod that was done to the ecu from my understanding. In that thread (and many others that I've seen) the Chipped ECU that guy bought had the wrong transistor installed.
I was talking about using a stock ECU for that engine in case he was using a chipped one and it was fucked up.
OP never said what egine/ecu/etc etc he had. So it's possible.
