vtec problem
Old Aug 15, 2005 | 09:51 AM
nonphixion46's Avatar
nonphixion46 has disabled reputation
Default vtec problem
it didnt seem to do this before i did a full tune up . but my vtec seems to drop off and come back on once i hit like 7 grand, it doesnt do it at the same rpm everytime, its random, but it is when im getting on it, not around 6 or anything. i can feel both first and second stage vtec fading in and out. so where do you think my problem lies. what should i start checking first? any help is usefull for me. thank you.
Dan. oh its a B18C
Old Aug 15, 2005 | 09:54 AM
Lord_Vegeta's Avatar
R U SeRiOUS?
Lord_Vegeta Lord_Vegeta Lord_Vegeta Lord_Vegeta Lord_Vegeta Lord_Vegeta Lord_Vegeta Lord_Vegeta Lord_Vegeta Lord_Vegeta Lord_Vegeta
Default Re: vtec problem
Make sure you have the proper amount of oil.
Old Aug 15, 2005 | 10:02 AM
ok with that issue, i had a pretty bad leak from my valve head gasket. so i dont know how much leaked out. but i put oil back in it till i reached the top bar on my oil stick.. ?
Old Aug 15, 2005 | 11:14 AM
sircrx's Avatar
Boost is Better
sircrx sircrx sircrx sircrx sircrx sircrx sircrx sircrx sircrx sircrx sircrx
i had the same problem with my b18 but it wasnt vtec going out it was losing fuel so it would die from that. i had to get a new high flow fuel pump but not sure if that is the same prob.
Old Aug 15, 2005 | 11:39 AM
yeah already got a desent sized fuel pump, it just started doing this
Old Aug 15, 2005 | 02:10 PM
DORKO's Avatar
Bearded.
maybe the actual vtec solenoid is either bad, or either the vtec wire (green w/yellow stripe) isnt connected properly or is shorting out some where
Old Aug 15, 2005 | 02:23 PM
GotB00stPsi's Avatar
GotB00stPsi is an unknown quantity at this point
Old Aug 15, 2005 | 02:35 PM
is there a oil filter of some sort or like a screen in the solinoid?
Old Aug 15, 2005 | 05:00 PM
DORKO's Avatar
Bearded.
yes there is a screen for the vtec solenoid...take it off and either buy a new one or clean it out..
i suggest you buy a new solenoid with a screen..., and do a continuity (sp) check on the actual vtec wire its self...check it at the ecu and at the actual solenoid
Old Aug 15, 2005 | 05:21 PM
stockhfcrx's Avatar
another honda
stockhfcrx is an unknown quantity at this point
car has to be at wot for vtec iirc
