turbo help...
Re: turbo help...
I don't believe Tial makes a 50mm wastegate, they make a 50mm blow off valve.
EDIT: Either way, there's only one way to install all of them: http://www.tialsport.com/documents/w..._wginstall.pdf
VPNOH
Re: turbo help...
Ok bro, the vaccuum line you are reffering to is what is called VANE PRESSURE. This vaccuum line will go from the turbo, to a Tee fitting, then on to the wastegate BOTTOM PORT. The other side of the Tee will go to one of the ports on the boost control solenoid, then the pther port goes back to the top port on the wastegate. Then you may or may not have another line coming off of the solenoid. If so, just leave this one venting to the atmosphere. I run a Tial 44mm Vband wategate and have no problems running my setup like this at 38psi.
zoomzoom
04-05-2008 06:58 AM
