truck battery?
Old Feb 18, 2008 | 02:20 PM
xrunna's Avatar
McLovin
xrunna has disabled reputation
Default truck battery?
i have a 2006 toyota x runner and i put new subs in abotu a month ago and now my battery keeps dying, i had this problem before when i first got the truck and i had subs installed but i took them out. i put new wires and fuses in. anyone no what the problem might be? could it just be the battery?
Old Feb 18, 2008 | 03:04 PM
aacjohnc's Avatar
Default Re: truck battery?
sounds like your amp is staying on after you turn the truck off . check to see if your remote wire is powering off the amp with the truck key off .if your still getting power to the amp with the truck key off then your remote wire is not hooked up correctly. the remote wire is normally blue for after market units .
Old Feb 19, 2008 | 01:06 PM
xrunna's Avatar
McLovin
i just went to look at it and when i turn the truck off the amp seems to go off, but i got a new amp because i thought that might be the problem but i guess not
Old Feb 19, 2008 | 01:40 PM
tabbsilverado's Avatar
tabbsilverado has disabled reputation
it could definetly be the battery , but there could be somethin else draining the batt, how long does it take for the battery to drain.
Old Feb 19, 2008 | 01:49 PM
xrunna's Avatar
McLovin
well i have had the subs in for like two months and now it wont start all the time, but when i took them out over the summer i had no problems. but it does it atleast once a week
CanonLst22
Sep 17, 2008 09:19 AM
