TPS CALIBRATION PROBLEM
Old 01-17-2011, 04:19 PM
EGhatchy89's Avatar
EGhatchy89 can only hope to improve
Question TPS CALIBRATION PROBLEM
Problem: I put TPS on B16A2 and calibrated the TPS closed to 0.48V thats as far as it would go, and wide open Throttle body is ONLY 3.6V Should be 4.5 to 5.0V!!!PLEASE GIVE FACTS OF WHAT IT MAY BE
Thank you guys for ALL the helpful info!!!!!
:wors hip:
EGhatchy89 is offline
Old 01-17-2011, 04:26 PM
rowe4166's Avatar
rowe4166 rowe4166 rowe4166 rowe4166 rowe4166 rowe4166 rowe4166 rowe4166 rowe4166 rowe4166 rowe4166
Default Re: TPS CALIBRATION PROBLEM
yes WOT should be 4.5 to 5 volts. with the throttle plate closed the tps should be reading .45 volts. Are you rotating the throttle arm by hand or the gas pedal ? If you are rotating it with the gas pedal it sounds like you need to tighten the throttle cable.
rowe4166 is offline
Old 01-17-2011, 04:33 PM
EGhatchy89's Avatar
No straight off TB outside of car!! its puzzling man its ERKING my nerves cuz ill never get the power thats there if I cant fix this problem
Old 01-17-2011, 04:35 PM
SG
C16EFSedan's Avatar
C16EFSedan has disabled reputation
The throttle body stop is too far extended is my guess. So its partially opening the butterfly even when completely sitting idle.
C16EFSedan is offline
Old 01-17-2011, 04:37 PM
EGhatchy89's Avatar
No butterflys on this I have what looks to be a Type-r replica ITM...didnt know you could adjust throttle body stop
Old 01-17-2011, 05:24 PM
VaDriven Mayhem
Lord Humongous's Avatar
It's your TPS reports.
You didn't get the memo?
Lord Humongous is offline
Old 01-17-2011, 05:25 PM
EGhatchy89's Avatar
WHAT?
Old 01-17-2011, 05:39 PM
Stiff Member
Laserjock's Avatar
Laserjock Laserjock Laserjock Laserjock Laserjock Laserjock Laserjock Laserjock Laserjock Laserjock Laserjock
oh snap, you went there!
any carbon buildup or obstructions in the opening?
Laserjock is offline
Old 01-17-2011, 05:44 PM
EGhatchy89's Avatar
by opening do you mean the TB or what?
Old 01-17-2011, 05:50 PM
Stiff Member
Laserjock's Avatar
huh, wat?
Yes the throttle body opening. Also perform the test with the tps off the throttle body to see if there is an installation erooor - or
Quick Reply: TPS CALIBRATION PROBLEM
