throttle body
Originally Posted by madcatz
if thats true then you can fit a s2k TB
I have a H23 sitting at the house and a B18b1 IM...ill try to line them up since the 23 and 22 use the same TB
they all fit. the difference is in the bore size. all the TB's have the same bolt pattern/tps/map sensor. i don't think an s2k TB will work because i've never heard of anyone doing it. but i know that the H22/B series/D series TB's are all interchangeable. however, if you upgrade to a bigger TB and do not match the bore of the IM to the bore on the TB...you will probably not see a damn difference in performance.
so if I can proove that a H23 TB works on a B18 IM, that then means a s2k TB will work on a D16 IM....wow Honda you may have done it again
Mike:
Preludes can attach the S2k TB to the stock manifold, we only have to rerun the coolant lines to make it work...kinda like using the Euro R H22/H23 TB on a USDM IM
