SWAP HELP!!!
Old Jul 17, 2007 | 06:26 PM
lilskud13's Avatar
lilskud13 has a reputation beyond reputelilskud13 has a reputation beyond reputelilskud13 has a reputation beyond reputelilskud13 has a reputation beyond reputelilskud13 has a reputation beyond reputelilskud13 has a reputation beyond reputelilskud13 has a reputation beyond reputelilskud13 has a reputation beyond reputelilskud13 has a reputation beyond repute
Default SWAP HELP!!!
I have a 99 civic dx and put in a d16a (JDM SOHC). The sohc is obd1. We got everything in except for a few plugs from the wiring harness and the car idles ok but when you give it gas it just breaks up. If you tap the gas to get to higher rpms its fine but when you mash it it struggles. I need help fast so any help will be great.
Old Jul 17, 2007 | 07:23 PM
99gsrcivic's Avatar
99gsrcivic has disabled reputation
Default Re: SWAP HELP!!!
my jdm swap did that and it tok me like 3 months to figure out that it was the injectors. Might try swapping them out for different ones. I know like b and d series injectors are the same i got d series in a gsr. Hope that helps. Also chech the GROUNDS. It will make a big difference if there loose or corroded.
Old Jul 17, 2007 | 07:56 PM
yboost's Avatar
yboost is an unknown quantity at this point
Yeah me and 99gsrcivic had a bunch of bullshit like that. but if the injectors dont help, try your plugs
sTohc4door
Engine / Exhaust / Drivetrain
Feb 18, 2009 05:23 PM
vtec2.0
Oct 31, 2008 11:10 PM
