stereo problems
Old Mar 16, 2010 | 11:55 AM
cmjw11's Avatar
cmjw11 cmjw11 cmjw11 cmjw11 cmjw11 cmjw11 cmjw11 cmjw11 cmjw11 cmjw11 cmjw11
Default stereo problems
I have a used 99 ford expedition i purchased a few years back. It had an aftermarket deck when i purchased it and everything was fine until a week ago when my music started cutting off all of a sudden. Ever since then If i turn the radio on it works and music plays but after 5-10 sec the music cuts off completely. The radio still functions and displays but no sound what so ever plays. Jus silence. I checked any and all fuses i could think of and all are good to go. I was curious as to what my problem could be. If you guys could give me some things to go off of it would be great. Thanks
Old Mar 16, 2010 | 12:42 PM
Default Re: stereo problems
You probably have a shorted speaker output and the internal amplifier is shutting off from a thermal fault. It may also be a fatigued solder joint inside that is losing contact when it heats up slightly. Take out the radio and check the resistance of the speakers at the radio connector with a multimeter. They aren't going to measure the same as what their rated impedance is, so an 8 ohm speaker doesn't have a DC resistance of 8 ohms. You're just looking for a noticeable short. If you don't find anything, chances are good that the head unit has problems and needs to be repaired or replaced depending on how much it's worth.
Old Mar 24, 2010 | 10:37 PM
jasonarea51's Avatar
jasonarea51 has disabled reputation
^^^^^what he said^^^^ if you are not running a separate amp to your speakers you really dont have a reason to think it's the speakers either your head unit isn't grounding out properly, or sadly to say your head unit's days are numbered.
BigCno
23
Apr 5, 2010 04:46 PM
SupraTT804
Dec 30, 2009 12:18 PM
ShawnD
Dec 27, 2007 06:07 PM
trini ef racer
Jun 21, 2006 06:07 AM
trini ef racer
Nov 29, 2004 01:05 PM
