start up problems
Old Aug 19, 2004 | 07:25 PM
HondaCRXsiHatch's Avatar
Project in the makin
HondaCRXsiHatch is an unknown quantity at this point
Default start up problems
runnin an 89 crx si and when i start my car most of the time it will bog down and will take me a while to get it started back up but if i start it and give it some gas right a way it will be fine and also my rpm's will run really low below .5 (500 rpm) at idle. and will fluctuate a lot. i have it looked at by the honda dealer ship them selves including some little shops around town and they all say it check out fine. could it possibly be a compression problem?
Old Aug 19, 2004 | 07:40 PM
themacuser.org's Avatar
i got 5 on it
themacuser.org is infamous around these partsthemacuser.org is infamous around these partsthemacuser.org is infamous around these partsthemacuser.org is infamous around these partsthemacuser.org is infamous around these partsthemacuser.org is infamous around these partsthemacuser.org is infamous around these partsthemacuser.org is infamous around these partsthemacuser.org is infamous around these partsthemacuser.org is infamous around these partsthemacuser.org is infamous around these parts
Default Re: start up problems
it good. compression no problem. ok.
Old Aug 19, 2004 | 11:14 PM
GIMMEAN"H"'s Avatar
cibic weetec
GIMMEAN"H" has a reputation beyond reputeGIMMEAN"H" has a reputation beyond reputeGIMMEAN"H" has a reputation beyond reputeGIMMEAN"H" has a reputation beyond reputeGIMMEAN"H" has a reputation beyond reputeGIMMEAN"H" has a reputation beyond reputeGIMMEAN"H" has a reputation beyond reputeGIMMEAN"H" has a reputation beyond reputeGIMMEAN"H" has a reputation beyond reputeGIMMEAN"H" has a reputation beyond repute
could be poor spark, could be a bad ground...could be your idle valve. how olds the alternator?
Old Aug 20, 2004 | 01:31 AM
MerF's Avatar
Ghost
LMAO...your humor shall not go un-noticed.
Is an 89 carb or EFI? If it's carb you need it cleaned and tuned.
If it's EFI you have a vaccuum line off somewhere.
Nowhere could I imagine an alternator even remotely causing this fault.
Old Aug 20, 2004 | 01:55 AM
crxnfx's Avatar
I have a 20 valve...
yep, an alternator problem would be hesitation while driving, bad gas mileage, and running way to rich.
i don't think 89 si's where carburated, so check your vacuum lines, look under the hood and chase the diagram, make sure everything is hooked up correctly.
Did you add anything new lately?
Old Aug 20, 2004 | 02:41 AM
HatefulMechanic's Avatar
The Pro to call.
hehehehe....i have seen it several times.
ECU's dont like AC voltage, nor do they like too much or too little DC voltage.
Old Aug 20, 2004 | 09:31 AM
MerF's Avatar
Ghost
Learn something new every day. The Supra just gives me a light, shuts off when the battery dies, and asks for $480 for the new one.
Old Aug 20, 2004 | 09:58 AM
flow fx's Avatar
hostgator.com
flow fx is infamous around these partsflow fx is infamous around these partsflow fx is infamous around these partsflow fx is infamous around these partsflow fx is infamous around these partsflow fx is infamous around these partsflow fx is infamous around these partsflow fx is infamous around these partsflow fx is infamous around these partsflow fx is infamous around these partsflow fx is infamous around these parts
dude... it's like $80 to rebuild one.
Old Aug 20, 2004 | 10:05 AM
MerF's Avatar
Ghost
Me = stranded in Florida getting married at my in-laws house. didn't know f any reputable eletric motor shops, and I was due to report off of leave in 2 days (back here)...gotta do what you gotta do.
Old Aug 20, 2004 | 03:52 PM
The Pro to call.
yeah, and you must love Toyota and their ingenious placement of their alternators....
if you have any other form of sway bar then stock (and most stock ones) you gotta drop it to get it out...
