sr20det problem
Old 01-09-2006, 05:44 AM
240 SR's Avatar
240 SR is an unknown quantity at this point
Default sr20det problem
i replaced the battery yesterday in my sr20 and then when i went to start it my starter just spun. i tried to push start it but it would kick then bog down.
now when i try and start it the motor wont turn over, i dont think the plugs are getting any spark, the blower on the inside wont work, the lights wont flip up, and a bunch of fuses have no power (just to name a few of the problems)
please help!!!
240 SR is offline
Old 01-09-2006, 07:33 AM
#XV
El Negro's Avatar
El Negro is a splendid one to beholdEl Negro is a splendid one to beholdEl Negro is a splendid one to beholdEl Negro is a splendid one to beholdEl Negro is a splendid one to beholdEl Negro is a splendid one to beholdEl Negro is a splendid one to beholdEl Negro is a splendid one to behold
Default Re: sr20det problem
Ignitor chip?
Was the car running well before you replaced the battery, or had the battery died?
El Negro is offline
Old 01-09-2006, 09:12 AM
jspecS13's Avatar
jspecS13 has disabled reputation
please help!!!
could be several things.
cranks but does not start = Usually starter like what he said
A bunch of lights/windows/etc doesnt work = ALT fuse in the engine bay
or
your battery terminals arent on secure...
we'll go from there..
jspecS13 is offline
Old 01-09-2006, 10:00 AM
240 SR's Avatar
the car was running fine before i replaced the battery, i accidentally switched the terminals.
im gonna try the ignitor switch and then i guess the starter
240 SR is offline
Old 01-10-2006, 09:25 AM
Lost Cat Magnet
drifterJERRY's Avatar
drifterJERRY is an unknown quantity at this point
you fried the ignitor....have seen it happen many many times before.
drifterJERRY is offline
Old 01-10-2006, 01:24 PM
NEO VVL N1 BITCHES
JJSpinALot's Avatar
JJSpinALot JJSpinALot JJSpinALot JJSpinALot JJSpinALot JJSpinALot JJSpinALot JJSpinALot JJSpinALot JJSpinALot JJSpinALot
i agree if you switched the terminals. at least they are easy to get these days.
JJSpinALot is offline
Old 02-08-2006, 02:55 PM
el 240 de azbel's Avatar
el 240 de azbel is an unknown quantity at this point
easy but expensive
el 240 de azbel is offline
Old 02-08-2006, 05:48 PM
RedSuns's Avatar
RedSuns has disabled reputation
the ignitor might be fine but like someone said check the fuse panel under the hood
RedSuns is offline
Old 02-09-2006, 03:58 AM
Greaser's Avatar
Greaser has a reputation beyond reputeGreaser has a reputation beyond reputeGreaser has a reputation beyond reputeGreaser has a reputation beyond reputeGreaser has a reputation beyond reputeGreaser has a reputation beyond reputeGreaser has a reputation beyond reputeGreaser has a reputation beyond reputeGreaser has a reputation beyond repute
please help!!!
i guarantee you put your battery on backwards.
Greaser is offline
Old 02-09-2006, 04:34 AM
master debater
blackout's Avatar
blackout blackout blackout blackout blackout blackout blackout blackout blackout blackout blackout
kind of a big thing to overlook when trying to diagnose the problem huh?
trust me, you are not the only one. i just did the same exact thing about 3 months ago.
this is what probably happened, although every case is different when you're talking unpredictable electricity.
- alternator fuse is guaranteed to be blown. it's a 75A fuse in the main fuse compartment in the engine bay. gray in color. $20 at a nissan dealer to replace.
-get a new fuse, it will crank, but may not start. if it doesn't start, 99.9% chance you blew your ecu. i now have an inoperable power fc because of my moment of negligence. check ebay when looking for a new one unless you have a hookup. most of the 240 parts sites want at least 250-300 for a 62/e5 ecu (red top, zenki black top), and more for a j4 (kouki blacktop)
but as i said before, i've read on freshalloy of people only blowing the fuse, and everything else is fine. most often the ecu will go though.
blackout is offline
Quick Reply: sr20det problem
