sound system
Old 11-17-2011, 05:58 AM
steelerfan6898's Avatar
steelerfan6898 has disabled reputation
Default sound system
my 94 civic came with an old alpine, but when i went to take it out and put my pioneer in it the deck didnt work. So then i tryed putting the alpine back in and it too doesnt work. I tryed cutting everything up to the relay and hard wiring both the decks and nothing is still working, so if anyone knows what the problem is with my 94 ex please let me know.
steelerfan6898 is offline
Old 11-19-2011, 12:05 PM
aacjohnc's Avatar
Default Re: sound system
you have no power and probly a bad ground , check your fuse from where ever your pulling the power from . or get a volt meter and check your - and postive connections. btw is your constant wire hooked up?
aacjohnc is offline
Old 11-19-2011, 05:40 PM
You probably shorted the constant power wire to dash frame and blew the fuse. If it worked before and it doesn't work now, it's going to be something really simple and really easy to find.
Old 11-20-2011, 02:29 AM
trickyricky's Avatar
trickyricky trickyricky trickyricky trickyricky trickyricky trickyricky trickyricky trickyricky trickyricky trickyricky trickyricky
Search and download the wiring diagram for your vehicle so you know which wire should have +12vdc, ground, etc...
trickyricky is offline
Old 11-20-2011, 08:30 AM
well i checked all my fuses and there good, but i took it to my old shop and took a test light to it and onyl one wire is getting power and it only gets power when the car is on, so my acc is not getting power at all. And my grounds are all good
Old 11-20-2011, 10:05 AM
TonzAGunz
Dubee88's Avatar
Dubee88 Dubee88 Dubee88 Dubee88 Dubee88 Dubee88 Dubee88 Dubee88 Dubee88 Dubee88 Dubee88
no that is your accessory...you dont have constant. does your dome light still work? how about your door chime? check those fuses if not
Radio 12V white/blue
Radio Ground black
Radio Ignition yellow/red
Left Front Speaker (+/-) blue/green - gray/black
Right Front Speaker (+/-) red/green - brown/black
Left Rear Speaker (+/-) blue/yellow - gray/white
Right Rear Speaker (+/-) red/yellow - brown/white
Last edited by Dubee88; 11-20-2011 at 10:09 AM. Reason: spoonfeeding info to the noob
Dubee88 is offline
Old 11-20-2011, 11:05 AM
Temporary ######
Brian_O'Connor's Avatar
Brian_O'Connor Brian_O'Connor Brian_O'Connor Brian_O'Connor Brian_O'Connor Brian_O'Connor Brian_O'Connor Brian_O'Connor Brian_O'Connor Brian_O'Connor Brian_O'Connor
Check your fuse panel under your hood. Had the same issue in my accord. Turns out it was a blown fuse.
Brian_O'Connor is offline
Old 11-20-2011, 09:19 PM
dome light has never worked but my chime works all the time sooo.....
Old 11-21-2011, 03:57 AM
White Devil's Avatar
...........still possibly a bad fuse.
YOU NEED A DAMN WIRING DIAGRAM FOR YOUR DAMN CAR. TRACING OUT YOUR WIRES WILL TELL YOU WHICH FUSE IS BAD.
AND... A FUSE CAN LOOK ABSOLUTELY FREAKING NORMAL AND STILL BE BLOWN.
http://www.youtube.com/watch?v=ZDgy3S2B8KI http://www.youtube.com/watch?v=dYOc0oFOThc&feature=related INVEST IN A MULTIMETER.
http://www.youtube.com/watch?v=bF3OyQ3HwfU&feature=related
White Devil is offline
Old 11-23-2011, 11:02 AM
TonzAGunz
Dubee88's Avatar
sooooo you still have an issue. and if you have power when the car is on and no power when its not, then that is your switched/accessory power. not your constant. constant is just that, a constant source of power. if all else fails you can run a FUSED wire to your ignition harness but youre better off figuring what is wrong with that other one first
Dubee88 is offline
Quick Reply: sound system
