sc400 manual transmission?
Old Oct 18, 2008 | 05:50 PM
jdm240sx's Avatar
Antonio
jdm240sx has disabled reputation
Default sc400 manual transmission?
ok so this most likely has been posted up, but there is a rumor going around saying that a company in Australi made a manual transmission for the stock v8 sc400. if so do they have a web site or anything. i've tryed to search to see if the rumor was true but got off track. thanks.
Old Oct 18, 2008 | 06:44 PM
RINTHAL's Avatar
*EXCITING!!!
RINTHAL is an unknown quantity at this point
Default Re: sc400 manual transmission?
lol just put a w58 in that shit silly!
Old Oct 18, 2008 | 06:51 PM
I wouldn't be surprised if someone made an adapter plate to use a readily available manual tranny with that engine. That's a fairly common thing to do. You'll probably need to replace the front section on the driveshaft (from the front joint forward) with something that has the correct spline pattern for the new tranny.
This really depends on what tranny is being used though, because if the new tranny is something like a Supra tranny there may be enough common parts to make it pretty easy. I don't know much about your specific car, just what generally has to happen for tranny swaps like that.
You may have to get a hybrid clutch too, using the pressure plate/flywheel from your engine and a friction disc that is splined for the new tranny.
Old Oct 18, 2008 | 07:09 PM
jdm240sx's Avatar
Antonio
w58 never heard of it but i just looked it up and it looks legit. So i just need the w58 tranny and the other stuff to convert it?
Old Oct 18, 2008 | 08:11 PM
WishIHadaSilvia's Avatar
I Roll Fenders
Are you looking to put a 1UZ in a 240? I am asking because of your screen name.
A guy did one into his 97 S14, he fabbed up his own mounts and made an adapter plate for the stock KA transmission so he could keep his stock driveshaft and everything. I believe for the clutch he used part MR2 and part something else random. You can search for it on google.
Old Oct 19, 2008 | 10:05 AM
jdm240sx's Avatar
Antonio
no my couzin just got one and he wants to keep the v8 because of the power but all the sc400 are auto not manual. so im trying to see if theres a manual tranny for that car. someone already said put a w58 in it. an those are in supras.
Old Oct 19, 2008 | 10:07 AM
intense2jz's Avatar
intense2jz is infamous around these partsintense2jz is infamous around these partsintense2jz is infamous around these partsintense2jz is infamous around these partsintense2jz is infamous around these partsintense2jz is infamous around these partsintense2jz is infamous around these partsintense2jz is infamous around these partsintense2jz is infamous around these partsintense2jz is infamous around these partsintense2jz is infamous around these parts
stick a r154 in it
Old Oct 19, 2008 | 10:19 AM
http://en.wikipedia.org/wiki/Toyota_W_transmission
Old Oct 20, 2008 | 05:58 AM
LSVTECEG757's Avatar
<3 2JZ
LSVTECEG757 has disabled reputation
they make an adapter plate for the supra 6 spd or you can gewt the parts:
http://www.clublexus.com/forums/show...t=sc400+6speed
Old Oct 20, 2008 | 12:11 PM
toyota_aristo's Avatar
toyota_aristo is a jewel in the roughtoyota_aristo is a jewel in the roughtoyota_aristo is a jewel in the roughtoyota_aristo is a jewel in the rough
This is for the 5 speed not the MKIV Supra TT 6 speed, which is a Getrag V160 Transmission.
