REVERSE KIT FOR HYDRO TO CABLE HELP!!!!
Old Mar 5, 2009 | 06:05 PM
PAWESOME's Avatar
PAWESOME has disabled reputation
Default REVERSE KIT FOR HYDRO TO CABLE HELP!!!!
I got a 93 eg 4 door...b20 turbowith a LS with LSD CABLE transmission. I don't want to get rid of the tranny unless i can finda good hydro for cheap or trade...
So i am deciding to just swap out the pedals...
Hasport mount for eg to cable
I already have the shift linkage/stabilizer custom made at my shop...
My question is....
IS IT JUST A SIMPLE SWAPOUT THE PEDALS WITH A CABLE SET AND CABLE IT UP...
OR IS THERE MORE THAN I THINK TO MY SOLUTION?
THANKS
Old Mar 5, 2009 | 06:13 PM
b16EFsedan's Avatar
peaches
Default Re: REVERSE KIT FOR HYDRO TO CABLE HELP!!!!
im pretty sure you got it....pedals and cable.......theres prbably lines to delete or change for fluids....my boy has a 92 cs with a cable tranny
Old Mar 6, 2009 | 03:32 AM
Yell88CRXsi's Avatar
Team Ultraspeed
take your pick...
Hasport: http://www.evasivemotorsports.com/Me...=HASPORT-EGBCC
Innovative: https://passwordjdm.com/Innovative-M...nt-P788C0.aspx
Old Mar 6, 2009 | 06:03 AM
c1turbo's Avatar
c1turbo will become famous soon enough
you dont have to swap pedals the mount kit moves the slave cylinder under the arm that the cable would connect to and the slave cylinder pushes the arm up to disengage clutch
Old Mar 8, 2009 | 03:26 AM
PAWESOME's Avatar
I understand the kit... just is there any pics on this setup on a car so that i can see it? cause i don't get it in a way. and why does the innovative mount look different than the hasport...(where itmounts to tranny is 2 totally diff setups?)
Chugger
Want to Buy / Trade ARCHIVE
12
Dec 15, 2008 06:06 PM
Chugger
Dec 14, 2008 12:15 PM
