remote start not starting
Old 04-27-2011, 03:14 PM
magic's Avatar
magic is an unknown quantity at this point
Default remote start not starting
I just got a new car that has aftermarket remote start. The unlock and lock function works. when i press the button to start my car, it cranks but shuts off before the car has a chance to start.I feel like if it cranked for a second longer it would work. Any advise would be greatly appriciated
magic is offline
Old 04-27-2011, 03:33 PM
Rigginit's Avatar
Rigginit has disabled reputation
Default Re: remote start not starting
Start with finding the brand and model of the unit. Some use a tach sense and other a direct tach wired input. others have a smart tach function. The unit may need just programmed again or perhaps one of these types switched to the other. Other causes could include a hood pin malfunction (Car wont start with an open hood/door/trunk usually) brake switch wire, Transponder bypass (chip in the key) and many other things.
Start with the units model and brand and go with the programming option first as its the easiest
Also posting the vehicle y/m/m would help others narrow down problems.
Rigginit is offline
Old 04-27-2011, 04:13 PM
I <3 MY EG
JustaGSR18's Avatar
JustaGSR18 has disabled reputation
what car? and what alarm? i do alarm work...
JustaGSR18 is offline
Old 04-27-2011, 04:27 PM
magic's Avatar
Unhappy Re: remote start not starting
95 integra.and its a ce0890 python.lock and unlock works.and car cranks but doesnt start.just noticed that the remote will start the car if the key is in the on position...what could it be
magic is offline
Old 04-27-2011, 05:54 PM
Rigginit's Avatar
They may have not fully wired it. I don't think the integra had a transponder until 2000-2001. They may have not used the ignition wire that operates the fuel pump and this would need to be connected.
just a possibility without looking at it ...
Try auto-starting it again and listen for the pump. also check that the heater/ac blows when the ignition kicks on and all the gauges operate as if it were the key starting it
Rigginit is offline
Old 04-28-2011, 05:09 AM
I <3 MY EG
JustaGSR18's Avatar
^ good explination.. sounds like no ignition.. there is no transponder in this car.. look under the dash there will be the brain then there will be a ribbon harness plugged into it, follow the ribbon harness and it will bring you to a relay pack. make sure the ribbon harness is plugged into the brain and relay pack securley, I have seen this problem before
Old 04-28-2011, 06:46 AM
magic's Avatar
what is the brain and ribbon pack and all that...haha idk the first thing about security.all i know is that theres a black button under the dash that has somethign to do with the remote start
magic is offline
Old 04-28-2011, 06:49 AM
I <3 MY EG
JustaGSR18's Avatar
where are you located? if around nova I can help.. if not bring it to a shop who can diagnose the problem
Old 04-28-2011, 06:50 AM
SG
C16EFSedan's Avatar
C16EFSedan has disabled reputation
Pay me to fix it
C16EFSedan is offline
Old 04-28-2011, 07:18 AM
TonzAGunz
Dubee88's Avatar
Dubee88 Dubee88 Dubee88 Dubee88 Dubee88 Dubee88 Dubee88 Dubee88 Dubee88 Dubee88 Dubee88
Im in Richmond and have over a decade of installing under my belt....im sure one of us can help you. Whats your location?
Dubee88 is offline
