Which rear disc setups will work?
"seriously....?"
I have an EK civic, 2dr. I am looking to get rid of my rear drums, but I am not sure which cars I can pull the setups off of. I know EK Si's, but what other cars with rear discs can I use?
WWW.TEAMDOHC.ORG
Re: Which rear disc setups will work?
Integra's or Del Sol's will work, but you will have to use your LCA's.GL makes a world of difference. You would be wise to do the fronts as well. I got front and rear from an Integra.
"seriously....?"
Aren't the fronts the same as mine? And would I take the Intergra trailing arm, and it still bolt on directly?
Sorry. Not really.
You will need the trailing arms, parking brake cables and LCA's. I'm pretty sure you will need the 40/40 prop valve but I could be wrong.
