RB25det swap input
Re: RB25det swap input
no dude, their is a tiny yellow button, under your break master cylinder that you have to push, and it does it alllllll by itself.*
*google is your friend
Whatever AT linkages, cables, harnesses, whatever the shift lever uses to control the trans. This might be a convenient time to switch to a manual transmission if you want, because you're replacing just about everything but the pedals anyway. I know what I'd do..
SAY IT WITCHA CHEST!
dont swap an rb25 if you're not going to make it a manual...you will be very disappointed, unless you're building a high horse power strictly drag car. what are you trying to do with the car?
Cross member for the engine, I believe custom Drive shaft, swapping in a rb25 costs something like 7-9k ask around zilvia and they will tell you everything you need.
