Radiator leak advice
Old 05-01-2009, 04:39 PM
FUCK!
JamesPrelude's Avatar
JamesPrelude JamesPrelude JamesPrelude JamesPrelude JamesPrelude JamesPrelude JamesPrelude JamesPrelude JamesPrelude JamesPrelude JamesPrelude
Default Radiator leak advice
The metal fitting, right under the radiator cap, that runs to the reservoir, is leaking. It's not a bad leak, but when the car heats up enough, a bit of coolant slips out pass the threads. What seems the most logical thing to do is to take some of the left over silicone that I use for the valve cover, coat the threads and screw it back in. However, I'd think it would be wiser to ask the knowledgeable people at VA driven what they would do, and if they ever had a similar problem. Thanks for the replies in advance.
JamesPrelude is offline
Old 05-02-2009, 06:55 AM
FUCK!
Default Re: Radiator leak advice
Anything? Maybe teflon tape? Or will that just burn up with the heat?
Old 05-02-2009, 07:07 AM
bugg_08's Avatar
bugg_08 has disabled reputation
try some j-b weld, it work for me.
bugg_08 is offline
Old 05-02-2009, 07:08 AM
MARK IT ZERO
ufctapout's Avatar
Big League Chew. Grape Flavor.
ufctapout is offline
Old 05-02-2009, 07:12 AM
VaDriven Mayhem
Lord Humongous's Avatar
replace the radiator or get it welded
Lord Humongous is offline
Old 05-02-2009, 07:15 AM
Slammedxpert
SortaFlush's Avatar
Replace the radiator. Don't be cheap on your cars cooling system. Rather have that band aid ass fix to get you by for....an hour-a week get you stuck in the middle of no where or possibly cause more damage?
Also, whatever you do don't use stop leak. That shit will clog up small coolant passages and just cause more trouble. Only use it if your in the boondocks with no other source of fixing it till you get back to civilization.
SortaFlush is offline
Old 05-02-2009, 07:36 AM
enot767's Avatar
enot767 has disabled reputation
jb weld it.. itll last longer then your car hah
enot767 is offline
Old 05-02-2009, 09:06 AM
FUCK!
It is a new radiator, that little plug circled in the second pic is what's fucking up. Is there a replacement for just that plug?
Old 05-02-2009, 08:41 PM
Slammedxpert
SortaFlush's Avatar
If it's new there should be a warranty.
Old 05-03-2009, 08:33 AM
brandon.beene's Avatar
brandon.beene can only hope to improve
Teflon tape works wonders, i had the same problem and i put teflon tape and it quit. hopefully you figure something out
brandon.beene is offline
Quick Reply: Radiator leak advice
