problems with p28 ecu w/ pix!
Means Slow
i just ordered a chipped p28 ecu. I installed and i started my car freaking thing does not idle well? the guy programmed the baseline but idles like shit! i cracked the ecu open and was looking throught circuitry board and found corrosion. first should it be idling like that without tune?
pictures of the corrosion i found.
Means Slow
Re: problems with p28 ecu w/ pix!
Plugs meaning the connector harness or the chip area? no the corrossion is just in that area. I have no idea what the base map is because i ordered the ecu online line and i just gave him the setup i had on my engine. my set up is a gsr motor turbo @ 7psi. jg intake manifold, 255 lph fuel pump, stock injectors(yes i know i have to up grade), vortech fmu. the p72 work fine. just when i install the p28 it goes crazy.
At some point, people will learn that a "basemap" is there simply to start the damn car and not expect it to run wonderfully. There is after all a reason why we use "chipped ECU's".
1.6L's of N/A fury!!
basemaps can be run for however long you want to. I'm about to run a basemap on my civic P06 until I get the money to tune. Granted, it wont run to its full potential but its a starting point. Is the chip soldered to the board or is it socketed and held in with zif socket? Look here:
Zif socket is the blue thing in the picture
http://www.xenocron.com/catalog/chip...cus-p-277.html
...also, if you need ecu stuff go here. They are great with excellent kits and prices. I actually bought the chip kit in the link.
TurboPipingSystems
Yup, basemaps will NOT necesarily give you a good idle. As mentioned, it is there to get the motor started. There are a few tuners in the area. Shad at Accuracy is the probably the best in the area. However, you can check with Matt Shue, Precision Auto, Dyno Inc., etc...
Means Slow
Means Slow
well finding out what the problem is. i have a bad chipped ecm! well okay thanks for the help! and Matt shue you are the best! cuz you got it right! im definetly taking to you for tuning!
