problem with crx sunroof motor
Old Aug 16, 2004 | 12:00 PM
gpeele's Avatar
still alive
gpeele gpeele gpeele gpeele gpeele gpeele
Default problem with crx sunroof motor
well sunroof will go down but wont go back. i was able to trouble shoot it to the motor. i took it apart and im getting about 12.5 and -12.5 across the brushes when i hit the sunroof switch. there was a large build up of brush dust that i cleared up and i thought was the problem. i put it back together and still no go in the foward direction. the windings looked fine no sign of burns or melted insulation. does anyone know what could be wrong with this motor.
Old Aug 16, 2004 | 12:19 PM
CHAHONDA's Avatar
corona connessuer
Default Re: problem with crx sunroof motor
could be a bad switch????
Old Aug 16, 2004 | 12:44 PM
gpeele's Avatar
still alive
i thought it was either that or the relay also but im getting both positive and negative voltage at the bushes of the motor when i hit the switch, it should be turnig but its not. im afraid to see what a new one will run me.
Old Aug 29, 2004 | 07:39 AM
sohcvtec's Avatar
sohcvtec has disabled reputation
I GOTTA SUNROOF MOTOR IF YOU ARE LOOKING FOR ONE 237-0338-STEVE
Old May 5, 2005 | 05:39 PM
bigbodycrx's Avatar
No more yellow
bigbodycrx has disabled reputation
how much for tha sunroof motor. drop a line on here
Old May 6, 2005 | 09:04 PM
00civichatch's Avatar
JAY SPEC
00civichatch 00civichatch
fuck crx sunroofs. my cousins rusted and flew off going down the high way.
Old May 9, 2005 | 01:42 PM
gpeele's Avatar
still alive
damn that car is long gone, im building a 240 circuit car for vir hpde and track days now.
Old May 10, 2005 | 05:30 PM
HondaCRXsiHatch's Avatar
Project in the makin
HondaCRXsiHatch is an unknown quantity at this point
had the same problem with my crx it was the switch for me i heard they go bad on those alot. but don't take my word for it if you think it is the motor then replace it. you said that you get power readings at the motor, from that it sounds like it is the motor.
Kana
Exterior
Mar 19, 2009 07:05 AM
Tim-Tim
Sep 25, 2008 03:32 PM
sneakerfreaker
Nov 12, 2007 05:57 PM
fgome001
Jun 10, 2007 07:41 PM
