Power door lock issue in 2001 civic ex.
JDMWHAT
2001 civic ex
Issue: power door locks not responding to switch inside on door. I do not have keyless on it, but it does have the power locks. I hear a clicking noise under steering column and the fuse is good under the hood but still not working. The lock knobs go up and down manually fine, no tight-ness.
Any thoughts?
Any thoughts?
Re: Power door lock issue in 2001 civic ex.
I'd suspect the switch works fine because you're hearing the relay click, but it sounds like the power to the lock actuators is not there. Find out what circuit the door locks are on, and check that fuse with a voltmeter to see if there is power there. Because none of the power locks are working, it's obviously going to be something that affects all of the lock actuators at the same time. That narrows things down a lot.
JDMWHAT
Ok fuse under hood gets power fine and fuse is good also. Anyone know if it shares power with anything else? All other accessories seem fine.
