Open Downpipe Problem
Old Oct 12, 2006 | 11:12 AM
strtfightncivc2's Avatar
strtfightncivc2 is an unknown quantity at this point
Default Open Downpipe Problem
Is it possible to run open downpipe and not get boost creep....we were tuning my car yesterday and it would hold 6lbs of boost until about 6000 and creep all the way up to 10lbs at redline and would creep higher with each gear.....i have the deltageate wastegate and i heard they are horrible but im also reading that you are goig to have creep with open downpipe no matter what....is this true and if not what wastegate should i get and does anyone have one for sell....thanks
Old Oct 12, 2006 | 04:03 PM
Ross's Avatar
Ross is an unknown quantity at this point
Default Re: Open Downpipe Problem
junk the deltagate. also what manifold are you using. If it is an ebay special I have seen those boost creep due to piss poor desighn. good luck.
Old Oct 12, 2006 | 05:00 PM
no its not an ebay special..i am using a Meunik manifold......so its not the open downpipe letting the boost creep up.....does anyone have any wastegates?
Old Oct 12, 2006 | 05:01 PM
Jarrod's Avatar
braap braap
I ran open downpipe on my 38mm Deltagate, no problems. 9lbs all the time.
I guess I had a factory freak
Old Oct 12, 2006 | 05:05 PM
g S x's Avatar
RIP Chris Schader
g S x g S x g S x g S x g S x g S x g S x g S x g S x g S x g S x
how big is your turbo? it could be too big for your wastegate.
Old Oct 12, 2006 | 05:06 PM
t3/t4 57 trim
Old Oct 12, 2006 | 05:08 PM
g S x's Avatar
RIP Chris Schader
i would try switching out the wastegate with a tial or something else.
Old Oct 12, 2006 | 05:10 PM
alright what size wastegate do you think i need?
Old Oct 12, 2006 | 05:12 PM
Jarrod's Avatar
braap braap
Is your wastegate line crump'd or collapse'd at all?
I'm currently using a Tial 38mm wastegate on a Turbonectics T3/To4-b trim. No issues at all, even though I never had a issue with my Deltagate.
Old Oct 12, 2006 | 05:16 PM
g S x's Avatar
RIP Chris Schader
38mm will be fine, also make sure you have a good size vacuum line running to the gate
