One Cylinder Not Firing - KA24DE
Old 11-28-2010, 06:09 PM
  #21
YANKYMATE!
lbs_ft's Avatar
Default Re: One Cylinder Not Firing - KA24DE
Originally Posted by nftuatn
drus car spits and stumbles like crazy when it warms up..ive pretty much narrowed it down to an ecu issue..just wanted to plug it in...i promise it wont hurt yours...
is his that black hatch?
lbs_ft is offline
Old 11-28-2010, 06:13 PM
  #22
baller/dickbutt#69
nftuatn's Avatar
yes.the one in the shop..
nftuatn is offline
Old 11-28-2010, 06:21 PM
  #23
YANKYMATE!
lbs_ft's Avatar
alright, no problem
lbs_ft is offline
Old 11-28-2010, 07:02 PM
  #24
dru
GUIBO!?
dru's Avatar
dru dru dru dru dru dru dru dru dru dru dru
awesome-o
if all works well I owe ya a beer
dru is offline
Old 11-28-2010, 07:08 PM
  #25
kulbordr's Avatar
kulbordr has disabled reputation
Step 1: walk into pick and pull/oceana salvage your choice.
Step 2: pull injectors off one of the 240s they have at location.
Step 3: place injectors in pocket.
Step 4: walk out.
Step 5: ???????
Step 6: Profit?
kulbordr is offline
Old 11-29-2010, 04:15 AM
  #26
Hijacker's Avatar
Hijacker Hijacker Hijacker Hijacker Hijacker Hijacker Hijacker Hijacker Hijacker Hijacker Hijacker
Have you looked at the distributor? A lot of times i see a misfire on these setups, it's dizzy related.
Hijacker is offline
Old 11-29-2010, 05:36 AM
  #27
YANKYMATE!
lbs_ft's Avatar
yeah, the plug is getting a spark. I checked the dizzy, the wires, and the plug. Still no change. I'll update this thread after I get back from nftuatn's
lbs_ft is offline
Old 12-04-2010, 08:58 AM
  #28
sk8erdude10230's Avatar
sk8erdude10230 has disabled reputation
had the same probelm wiht my motor unplug each injector one by one and see if it changes.... its a injector down i can assure u that... i thought my spark plugs were bad and my wires were abd shit i even replace3d my distributor and my coil and it still did it then i realized i had a bad injector
sk8erdude10230 is offline
Old 12-04-2010, 09:23 AM
  #29
Slomar's Avatar
Slomar Slomar Slomar Slomar Slomar Slomar
compressssionnn testtt
Slomar is offline
Old 12-07-2010, 06:57 PM
  #30
actionpaintball's Avatar
actionpaintball actionpaintball actionpaintball actionpaintball actionpaintball actionpaintball actionpaintball actionpaintball actionpaintball actionpaintball actionpaintball
NOID test first. Are you getting a code for a specific cylinder misfire? If you are getting a code, swap injectors and see if code follows teh injectors for the cylinder #, if it does-you found the bad injector,
actionpaintball is offline
Quick Reply: One Cylinder Not Firing - KA24DE
