oil in spark plugs.
Old 05-10-2008, 06:22 AM
Prey To Anguish
dsm93gsx's Avatar
dsm93gsx has disabled reputation
Default oil in spark plugs.
A question for the honda guys. I have a 90 ef si. I pretty much know what the problem is its the seals under the valve cover. I changed them with oem seals and the basterds still leak. I 've tried sealer and all kinds of sh"t. If anyone knows how to stop it please let me know.
dsm93gsx is offline
Old 05-10-2008, 06:39 AM
cleanEK's Avatar
Default Re: oil in spark plugs.
I have the same problem. Is all the nuts on your valve cover tight? Because I have two stripped ones and it's not sealing all the way.
cleanEK is offline
Old 05-10-2008, 06:53 AM
Prey To Anguish
dsm93gsx's Avatar
yeah there tight it just pisses me off. I don't want to do a tune up if its still leaking.
dsm93gsx is offline
Old 05-10-2008, 02:32 PM
Go Hard or Go Home
phreakvbhc's Avatar
phreakvbhc is infamous around these partsphreakvbhc is infamous around these partsphreakvbhc is infamous around these partsphreakvbhc is infamous around these partsphreakvbhc is infamous around these partsphreakvbhc is infamous around these partsphreakvbhc is infamous around these partsphreakvbhc is infamous around these partsphreakvbhc is infamous around these partsphreakvbhc is infamous around these partsphreakvbhc is infamous around these parts
im assuming you're speaking of the spark plug gaskets....you could try ultra black gasket maker.... i had the same problem a few weeks ago... the ultra black substantially helped the problem... but it wont completely stop until you take the cover off, clean all oil and debris out of the channels where gaskets go then either use the ultra black or try gettin the spark plug gaskets.
phreakvbhc is offline
Old 05-12-2008, 05:09 AM
Turbo VTEC-E
black6gen's Avatar
black6gen can only hope to improve
Cool Re: oil in spark plugs.
Well it could also be your valve guides. Try some Restore next time u do your oil change. That fixed my problem.
black6gen is offline
Old 05-12-2008, 06:33 AM
Holy $h!t its gold
hybridhondaz's Avatar
hybridhondaz is infamous around these partshybridhondaz is infamous around these partshybridhondaz is infamous around these partshybridhondaz is infamous around these partshybridhondaz is infamous around these partshybridhondaz is infamous around these partshybridhondaz is infamous around these partshybridhondaz is infamous around these partshybridhondaz is infamous around these partshybridhondaz is infamous around these partshybridhondaz is infamous around these parts
there are o rings under the rocker assembly get them from the dealer (not jus average o rings) pull the rocker assembly off replace the seals and adjust the valves when you put the rockers back on and should be good make sure you torque the rocker assembly down to spec.
hybridhondaz is offline
ravenracer
07-21-2007 10:17 AM
HEISENBERG
06-12-2007 03:22 PM
CxCBoY
06-09-2007 12:44 PM
xk84f9ds
12-04-2004 08:58 PM
J19
04-11-2003 04:30 AM
Quick Reply: oil in spark plugs.
