oil filter flex?
Old Oct 9, 2004 | 07:26 PM
gear's Avatar
Die reinste Bösen.
Default oil filter flex?
I was watching one of my best motoring videos...they were dicussing the insane load of a motor at high RPM's and what to do when you are prepping your car for racing on the track. One of Spoon's engineers suggested a 'trick' to keep your oil filter from flexing under high load situations. He displayed a picture of the oil filter on the block with a hose clamp (like you would use to secure a rubber hose fitting to a part of an intake tube) wrapped around it. I guess from the way he explained it, the clamp helps the oil filter retain its shape. Comming from a spoon engineer it sounded legit, but to me it just doesnt seem like an oil filter would be under that hard of a load. Any input?
Old Oct 9, 2004 | 07:40 PM
ThsPoq's Avatar
Thig Digged
ThsPoq ThsPoq ThsPoq ThsPoq ThsPoq ThsPoq ThsPoq ThsPoq ThsPoq ThsPoq ThsPoq
Default Re: oil filter flex?
Heat makes things expand..high rpms..high heat. Thats my assumption
Old Oct 10, 2004 | 12:40 PM
gear's Avatar
Die reinste Bösen.
true, but why would that effect anything major if the oil filter swells?
Old Oct 10, 2004 | 12:44 PM
mnchvgs79's Avatar
Custom User Title
mnchvgs79 is an unknown quantity at this point
Does an engine actually build enough oil pressure to swell a filter? and if it does, so what what would it hurt?
Old Oct 10, 2004 | 04:17 PM
HatefulMechanic's Avatar
The Pro to call.
if it is under that much pressure....it is possible that it is flexing (race engines at high rpm=high oil pressure) so it does sound feasable, to make certain that the oil isnt bypassing the media internally.
sounds weird. but if spoon builders do it...it is golden right?
Old Oct 10, 2004 | 06:13 PM
gear's Avatar
Die reinste Bösen.
you bet your sweet ass its golden...i guess extra reinforcement never hurt
Old Oct 11, 2004 | 03:28 PM
The Pro to call.
my ass is big...its not sweet
i guess that is their reasoning. i have seen one instance (not first hand, but close enough) of a filter rupturing, but it was due to a relief valve sticking in the oil pump)
Old Oct 14, 2004 | 01:12 AM
SolarEclipse's Avatar
Turbo? whats that
SolarEclipse is an unknown quantity at this point
hell if theres enough pressure to rupture an oil filter you can pretty much expect to have to replace all the bearings
Old Oct 14, 2004 | 04:12 AM
MerF's Avatar
Ghost
Sounds overboard to me, but honestly who the fuck am I?
Dustin Hastings
Sep 3, 2007 12:24 PM
marshallbc
Jan 25, 2006 03:42 AM
DrkIrny
Sep 25, 2003 08:00 AM
