Odd problem w/ stock 92 civic
Old 11-06-2007, 11:37 AM
registeredbeerdrinkr
mini-meturbodx's Avatar
mini-meturbodx is an unknown quantity at this point
Default Odd problem w/ stock 92 civic
When the car is around a half a tank it misses really bad and has horrible performance. feels like a timimg issue? but when I fill it up the problem Almost goes away. I have changed the fuel filter and no luck??
any help would be great
Thanks guys
mini-meturbodx is offline
Old 11-06-2007, 02:02 PM
4door_GSR's Avatar
4door_GSR has disabled reputation
Default Re: Odd problem w/ stock 92 civic
try changing the fuel pump it could be gettn weak and there is another filter on the bottom of the pump it could be lil stopped up a lil once your gas get half tank or less the pump is no longer submurged in gas so it gets hot and could be about to leave you stranded you can get a fuel pump from ebay brand new for $99 its easy to do if you didnt know just take out your lower back seat cushion and ull see where the wires run through a metal plate take it off and ull c
good luck
4door_GSR is offline
Old 11-06-2007, 02:07 PM
thanks, I figured that could be the case. The 92 civic did recieve a recall on the fuel pump.
Old 11-07-2007, 06:17 AM
I Love to Hate
B-Well's Avatar
good luck
I'd go ahead and grab a walbro255 if you're gonna be replacing you mine as well upgrade at the same time.
B-Well is offline
Old 11-07-2007, 09:11 AM
www.CM-R.net
CavemanRacing's Avatar
CavemanRacing CavemanRacing CavemanRacing CavemanRacing CavemanRacing CavemanRacing CavemanRacing CavemanRacing CavemanRacing
Why the fuck would you put a 255 in a stock 1.5 liter?
CavemanRacing is offline
Old 11-07-2007, 09:13 AM
corona connessuer
CHAHONDA's Avatar
ditto........good way to get poor fuel mileage and black smoke
CHAHONDA is offline
Old 11-07-2007, 10:02 AM
I Love to Hate
B-Well's Avatar
If he keeps his honda stock he's 1 in 120,304.4. Just about every honda is going to be modded and it's always better to upgrade when you're replacing a part. If He's not changing injectors or the fuel pressure there won't be any smoke or overcomsumption of fuel. The pump is just more efficient. The presure is not being increaced nor is the injector pulse width.
B-Well is offline
Old 11-07-2007, 10:15 AM
www.CM-R.net
No
No
Wat
If He's not changing injectors or the fuel pressure there won't be any smoke or overcomsumption of fuel. The presure is not being increaced nor is the injector pulse width.
Incorrect. You are increasing pressure at the fuel rail. More fuel flow at the same pulse.
Old 11-07-2007, 10:16 AM
corona connessuer
CHAHONDA's Avatar
fuel pressure will increase due to the stronger flow of the fuel pump.......i have already done what you are speaking of. walbro 255 in a stock civic. the results where less than ideal.
CHAHONDA is offline
Old 11-07-2007, 11:05 AM
You'll only increase fuel pressure if the stock fuel regulator can't flow enough to regulate the higher flow of a beefier pump, and you're not consuming enough on the other side of the regulator to keep the pressure differential low..
Quick Reply: Odd problem w/ stock 92 civic
