obd0-obd1 ef civic conversion
TurboPipingSystems
90hatch w/ d16y8
Re: obd0-obd1 ef civic conversion
I'm running eg injectors, thers 8 wires altogether, brown red yellow and lightg blue, these four are already hooked up to the ecu, the other4 wires are yellow and black, they run to the conjunction box, were do I hook the box up to on the ecu
Conjunction box? Is that a coordinating, subordinating, or correlative conjunction box? (conjunctions are a part of grammar, a conjunction box doesn't exist...)
Maybe you're talking about a resistor box? If that's not what you're talking about, I have no clue.
If you're using EG injectors (high impedance), you don't use the resistor box. Resistor boxes are for the earlier (low impedance) injectors. The black and yellow wires from the injectors get connected to ignition switched power.
90hatch w/ d16y8
Thanks man, ya its not the resitor box, its la clip where eseven wire go into to conect them all together ill take a pic of it
90hatch w/ d16y8
here's a pic like i said there 8 wires, 2 on each injector, one brown, one yellow,one red, one blue and 4 yellow w/ black strips, all for yellow w/ black strips runs to this junction box, were do i connect them two?
in this picture i used purple for the yellow w/ black stripe
