NoS??
Old Nov 28, 2003 | 11:37 AM
a92civicxjdmb16's Avatar
a92civicxjdmb16 is an unknown quantity at this point
how much do they run?
Old Nov 28, 2003 | 01:07 PM
MattnTheHATch's Avatar
DAAAANG & OHDAANG
MattnTheHATch MattnTheHATch MattnTheHATch MattnTheHATch MattnTheHATch MattnTheHATch MattnTheHATch MattnTheHATch MattnTheHATch MattnTheHATch MattnTheHATch
well they cost around $1,000 a bolt, but as long as you use walmart performance parts you can get hooked up with a sponsorship inwhich they give you the bolts, its quite a deal
Old Nov 28, 2003 | 01:32 PM
TheGentleArt's Avatar
DA LEPRAHKAHNZ GOLLD
TheGentleArt TheGentleArt TheGentleArt TheGentleArt TheGentleArt TheGentleArt TheGentleArt TheGentleArt TheGentleArt TheGentleArt TheGentleArt
thanks guys, i didnt meen the brand nos, just ment nitrous, tried to keep it shortened, i would also like to know a good brand? i hear venom/zex alot thanks.
Old Nov 28, 2003 | 01:34 PM
nickyroo's Avatar
haha give the newbies a break, assholes
there are two kinds of kits. a dry kit is just a line from a bottle hooked to a solenoid that opens when you hit the button. nitrous sprays into your intake and your injectors compensate for the extra air thats coming in. a wet kit is a dry kit plus a line from a fuel outlet such as a test fitting on your fuel rail. it sprays fuel into your intake so your injectors do not get overloaded when you push 150hp worth if nitrous through your motor. both have their advantages. dry is easier to hook up i guess, wet will allow you to spray more nitrous and is easier on your fuel pump/injectors.
either way, the nitrous comes from a spray nozzle that is tapped into your intake elbow.
Old Nov 28, 2003 | 01:39 PM
DAAAANG & OHDAANG
get the bolts dude, if not your gonna be seeing your muffler flying into the windshielf of the car behind you... godspeed.
Old Nov 28, 2003 | 02:34 PM
also when u get the nitrous kit ull get THE FAST AND THE FURIOUS fire out of ur muffler!!!!!! =)
Old Nov 28, 2003 | 02:48 PM
vmspionage's Avatar
SOI SOI SOI SOI SOI
vmspionage vmspionage vmspionage vmspionage vmspionage vmspionage vmspionage vmspionage vmspionage vmspionage vmspionage
make sure to invest in subframe floorpan supports
Old Nov 28, 2003 | 03:27 PM
AllMotorModular's Avatar
poop banana owns you
AllMotorModular is an unknown quantity at this point
don't forget to get the whole kit. you can get the bolts by themselves, or the kit wich has the nuts and washers, and the lube and oil you'll need for proper installation.
Old Nov 28, 2003 | 03:39 PM
g S x's Avatar
RIP Chris Schader
g S x g S x g S x g S x g S x g S x g S x g S x g S x g S x g S x
youll need 2 big bottles because the bigger the bottles and the more you have of them the faster it will make you! and get the bolts definately! i had my 3A racing muffler blast off and killed a kid that was following me on a moped.
Old Nov 28, 2003 | 03:49 PM
DAAAANG & OHDAANG
HAHAHAHAHAHA, thats why i stress the bolts so much
