NO POWER TO ECU!!!
Old 12-09-2009, 07:12 PM
fstdc2's Avatar
fstdc2 has disabled reputation
Default NO POWER TO ECU!!!
OK guys i am in need of some help here! i just finished installing my motor and turbo kit. after i put it in and fired it i noticed a leak coming from my heater core so i pulled the dash off and fixed it, and put the dash back on... went to fire the car and bam, no power to the ecu????? i checked all the fuses and they are okay! is there a ground wire or something i missed???? Also the car has an alarm system could that cause the ecu to not get power???? the car is a 98 integra coverted to obd1 with s300
thanks in advance for the help!!!!!
fstdc2 is offline
Old 12-09-2009, 08:26 PM
LOLH8RS
straightHYPE's Avatar
straightHYPE has disabled reputation
Default Re: NO POWER TO ECU!!!
could be a main ecu ground you could have pinched a wire when u put the dash back in theres a little side mounted fuse panel near the main panel that has an ecu power fuse check that
straightHYPE is offline
Old 12-10-2009, 04:30 AM
fstdc2's Avatar
Thanks man I will check there also
fstdc2 is offline
Old 12-10-2009, 09:42 AM
Oh, here's what you do. Unplug the ECU, and do a continuity check between the ECU connector ground and chassis ground. If you get a resistance reading higher than almost nothing, it's a ground problem. Then check power between the ECU connector power and chassis ground. There are two power inputs, one is an ignition switched power and one is a constant power for volatile memory backup (just like your radio with the station presets).
Basically you need to find out what you have, and what you don't have, so you don't just go mindlessly taking the car apart trying to find possible causes when you don't know what you're looking for.
Old 12-10-2009, 11:50 AM
fstdc2's Avatar
Thanks man I'll give that a try also
fstdc2 is offline
Old 12-12-2009, 10:52 AM
b182boost's Avatar
b182boost has disabled reputation
nice break down fabrik8,i'm gonna hit you up for some electrical issues i'm having
b182boost is offline
VAVolvo
Engine / Exhaust / Drivetrain
02-09-2009 01:57 PM
madsteez
02-03-2009 10:42 AM
TrePound
11-25-2006 08:48 AM
Quick Reply: NO POWER TO ECU!!!
