newbie needs help again :(
Old Dec 9, 2005 | 12:50 PM
94redoemhb's Avatar
94redoemhb has disabled reputation
Default newbie needs help again :(
ok guys hopefully this will be the last dumb question.......ok so i get the ls motor and tranny...to install the turbo kit do i need to....put bigger injectors?if so what size is recomended.ecu upgrade or can i wait? how much boost is recomended to run on stock internals safely? buddy told me that upgrade the headgasket and i can boost the sh*t out of it is that true since the compression ratio is like 9.1 so im told. thanks so much
Old Dec 9, 2005 | 12:56 PM
Default Re: newbie needs help again :(
The general rule of thumb is about 8 PSI with the stock injectors, after that they can't flow enough, or are getting close enough to the edge of their safety margin that you should go bigger. You should get some type of fuel management to do the tuning, like a AFC or get the ECU chipped so it can be tuned. This is very necessary and has to be done if you get bigger injectors. This is assuming that you already have the correct ECU for your engine. I don't know much about boosted LS setups, just what's required to keep the fuel system happy and tuned. Someone else has to jump in for the rest of the stuff.
T-solara99
Aug 7, 2006 09:51 AM
boostlesszx2
Dec 13, 2004 09:47 PM
~Squigley~
Oct 22, 2004 07:40 AM
Ep Turdo
Oct 2, 2004 05:18 PM
phknls
Sep 13, 2004 11:46 AM
