Need speedometer help (HONDA TECH'S HELP)
Old Sep 10, 2004 | 05:21 PM
boostedgsrcivic's Avatar
Stock for Now!!
boostedgsrcivic is an unknown quantity at this point
Angry Need speedometer help (HONDA TECH'S HELP)
i got a 94 b16 turbo civic and the speedo doesnt work throwing vss code no vtec / no boost
Things i've checked
1.changed vss
2.swapped speedometer
3.checked thermostat ground
Old Sep 11, 2004 | 08:13 AM
Stock for Now!!
Default Re: Need speedometer help (HONDA TECH'S HELP)
help me
Old Sep 11, 2004 | 12:52 PM
xk84f9ds's Avatar
xk84f9ds is an unknown quantity at this point
try replaceing your fuse box under your dash....that worked for me....its about 150$..but im sure you can find it off ebay for cheaper...
Old Sep 11, 2004 | 10:32 PM
Stock for Now!!
come on fellas no help
Old Sep 12, 2004 | 08:55 AM
mbui00's Avatar
mbui00 is a splendid one to beholdmbui00 is a splendid one to beholdmbui00 is a splendid one to beholdmbui00 is a splendid one to beholdmbui00 is a splendid one to beholdmbui00 is a splendid one to beholdmbui00 is a splendid one to beholdmbui00 is a splendid one to behold
www.honda-tech.com
Old Sep 12, 2004 | 03:05 PM
Stock for Now!!
Old Sep 12, 2004 | 03:13 PM
MA-HALF-E's Avatar
Awesome.
Check to make sure your speed sensor works. It's located on the back of the transmission, I believe it's two bolts. Unplug it, unscrew it, take it out carefully. Spray it with some type of cleaner. Re-install. Had the same problem, and that took care of it.
Old Sep 12, 2004 | 05:44 PM
Stock for Now!!
i did that took mine off and put it in my boys car and it worked in his car and his didnt work in my car
Old Sep 12, 2004 | 05:45 PM
Stock for Now!!
Thanks Any Other Suggestions
Old Sep 12, 2004 | 05:47 PM
HatefulMechanic's Avatar
The Pro to call.
have someone that knows what they are doing look at it instead of trying to have it fixed on the internet?
