need a little help with brakes
ok so when i start up my ef hatch and push the brake it makes a high pitched sound, it makes that sound even if the car is not rolling and it gets louder the farther down i push the brake. i can't figure it out can anyone help me with this?
Re: need a little help with brakes
any other symptoms??? is the brake pedal low? making any other noises? how do the brakes feel? have you looked at the brake pads? what model? drums in the rear? where is the noise coming from? front rear? etc etc
Originally Posted by ef9zc
(Post 3072902)
its just a vacuum noise. nothing to worry about. quite common... just try removing the vacuum hose going to the powerbooster behind the master cylinder and blow a little air in to get any junk out.
should i take it comletely off and blow air throw it or while one end is still on or what
i mean, take the hose off the nozzle connected to the power booster, and just blow a little air inside to make sure theres no junk/debris inside. Usually older cars make this squeek noise, just one of those things.
its your brake booster (if you have one....sounds like it is)
i have tried blowing throw the vac hoses but nothing has changes and i even replaced the little plastic thing too
check your proportioning valve located just under the resivour. it may need replaced
Originally Posted by katie
(Post 3119076)
if you are experiencing a stiff brake pedal and are hearing what sounds like a vacuum leak then you have a brake booster that has a defective diaphram. hence the vacuum leak. it kinda hard to properly diagnose your problem with out seeing the vehicle. does it make any noise at all if you do not depress the brake pedal? is the noise constant when your foot is on the brake? |
