need a little help with brakes
Old 05-16-2007, 06:51 PM
low n slow
757neon's Avatar
757neon 757neon
Default need a little help with brakes
ok so when i start up my ef hatch and push the brake it makes a high pitched sound, it makes that sound even if the car is not rolling and it gets louder the farther down i push the brake. i can't figure it out can anyone help me with this?
757neon is offline
Old 05-16-2007, 07:39 PM
ef9zc has disabled reputation
Default Re: need a little help with brakes
any other symptoms??? is the brake pedal low? making any other noises? how do the brakes feel? have you looked at the brake pads? what model? drums in the rear? where is the noise coming from? front rear? etc etc
ef9zc is offline
Old 05-17-2007, 03:40 AM
low n slow
757neon's Avatar
757neon 757neon
no other symptoms, car could stop on a dime, it has integra front brakes, drums in the rear, havent looked at the brake pads, its a 91 ef hatch. and the noise sounds like its coming from the brake master cylinder, i had a friend push on the brake while i was under the hood
757neon is offline
Old 05-17-2007, 09:22 AM
Die reinste Bösen.
gear's Avatar
its just a vacuum noise. nothing to worry about. quite common... just try removing the vacuum hose going to the powerbooster behind the master cylinder and blow a little air in to get any junk out.
gear is offline
Old 05-17-2007, 10:32 AM
low n slow
757neon's Avatar
757neon 757neon
should i take it comletely off and blow air throw it or while one end is still on or what
757neon is offline
Old 05-18-2007, 04:43 AM
Die reinste Bösen.
gear's Avatar
i mean, take the hose off the nozzle connected to the power booster, and just blow a little air inside to make sure theres no junk/debris inside. Usually older cars make this squeek noise, just one of those things.
gear is offline
Old 05-20-2007, 11:57 AM
I <3 My DSM
SPAWN's Avatar
SPAWN has much to be proud ofSPAWN has much to be proud ofSPAWN has much to be proud ofSPAWN has much to be proud ofSPAWN has much to be proud ofSPAWN has much to be proud ofSPAWN has much to be proud ofSPAWN has much to be proud ofSPAWN has much to be proud ofSPAWN has much to be proud ofSPAWN has much to be proud of
its your brake booster (if you have one....sounds like it is)
SPAWN is offline
Old 06-02-2007, 08:45 AM
low n slow
757neon's Avatar
757neon 757neon
i have tried blowing throw the vac hoses but nothing has changes and i even replaced the little plastic thing too
757neon is offline
Old 06-04-2007, 05:30 AM
katie has disabled reputation
check your proportioning valve located just under the resivour. it may need replaced
katie is offline
Old 06-04-2007, 06:19 PM
corona connessuer
that has nothing to do with it.
if you are experiencing a stiff brake pedal and are hearing what sounds like a vacuum leak then you have a brake booster that has a defective diaphram. hence the vacuum leak. it kinda hard to properly diagnose your problem with out seeing the vehicle. does it make any noise at all if you do not depress the brake pedal? is the noise constant when your foot is on the brake?
CHAHONDA is offline
Quick Reply: need a little help with brakes
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
