need help with waterpump..
Old 03-03-2009, 04:10 AM
slugish14's Avatar
slugish14 has disabled reputation
Default need help with waterpump..
ok so i think my water pump froze..how much and ow hard will this be to replace?? o its for a 99 si
slugish14 is offline
Old 03-03-2009, 04:16 AM
Gerber
Lil' G's Avatar
Lil' G is an unknown quantity at this point
Default Re: need help with waterpump..
froze? as in u had straight water .. no anitfreeze? if so .. it will unfreeze .. but id b more worried bout the block crackin
Lil' G is offline
Old 03-03-2009, 04:56 AM
slugish14's Avatar
yea..i had antifreez at one point but i have a VERY slow radiator leak and wen i put more in i jus put straight water...like wen i started the car this morn there was a wierd clicking kinda sound for like 2-3 secs then stoped and car sounded fine...i let sit till was warm and hen i went to drive the temp jus spiked up..
Old 03-03-2009, 05:02 AM
Fitty Tuckin
-JB-'s Avatar
Flush your coolant system. Get a new thermostat (they are cheap) get a new water pump (easy to install) and get a new radiator. Why are you going to run around with a bad radiator?
-JB- is offline
Old 03-03-2009, 05:06 AM
slugish14's Avatar
not absolutly pos that its the radiator leaking..jus my best geus..ive looked for any water leaks and cant fing anything...but i knw i have to add water like once a every month and a half..and i looked at replacing waterpump and it didnt seem soo easy..
Old 03-03-2009, 06:55 AM
Fitty Tuckin
-JB-'s Avatar
Water mixing with oil in the motor?
-JB- is offline
Old 03-03-2009, 06:58 AM
Sorry. Not really.
BentValve's Avatar
BentValve BentValve BentValve BentValve BentValve BentValve BentValve BentValve BentValve BentValve BentValve
If there are no leaks, it could be your head gasket.
BentValve is offline
Old 03-03-2009, 07:04 AM
ohh yea
integrab17's Avatar
integrab17 has disabled reputation
where exactly is it leaking from??
integrab17 is offline
Old 03-03-2009, 07:19 AM
slugish14's Avatar
no oil mixing wit water..and honestly the only prob iv e had b4 this is my check engine light jus came on..i ran code and its shootn me a o2 sensor and the other one is a vtech code..but im n process of fixing that..im pretty sure my prob right now is i let my water pump freez..how will i knw wen its thawed back out? and if i need to replace it?
Old 03-03-2009, 07:41 AM
Digital Life
83Stang5.0's Avatar
If you still have ice in it, dont run it. If theres a possibility of it still being frozen, dont run it at all. Even though you could have already ruined the pump, you dont want to risk anything else.
Flush the system, refill with antifreeze, new thermostat, and then try again. If you get temp spikes then, its the pump or a really bad radiator.
83Stang5.0 is offline
