NEED HELP W/ FIELDS ON MINIME!!!!
Old 03-13-2004, 03:24 PM
HASSELHOFF!
yllalnad's Avatar
yllalnad yllalnad yllalnad yllalnad yllalnad yllalnad yllalnad yllalnad yllalnad yllalnad yllalnad
Default NEED HELP W/ FIELDS ON MINIME!!!!
a friend and i hooked up my Fields vtec controller on my 89 hatch with a mini me swap.... we used the diagram for an ef with a b16. everything is hooked up as said in the diagram (except for vtec which is directly to the solenoid). When finished we turned the car on than turned the fields on and the bastard putted, also no vtec engagement. So now i have to keep the fields off in order for my car to run normal... anyways just wondering if anyone has any ideas
sank you
dan
yllalnad is offline
Old 03-13-2004, 05:11 PM
Justa lil 6
Dang Yo's Avatar
Dang Yo is a jewel in the roughDang Yo is a jewel in the roughDang Yo is a jewel in the roughDang Yo is a jewel in the roughDang Yo is a jewel in the rough
Default Re: NEED HELP W/ FIELDS ON MINIME!!!!
mine works perfect... check all your connections, mine turns on with the car and i was told that if i turn the fields off my car will not run right so make sure you wired it correctly and change it to where the vtec wires run to the ECU and the tap into those for the fields, dont run it str8 to the solenoid, i have heard of people burning up there solenoid like that
Dang Yo is offline
Old 03-13-2004, 05:13 PM
Justa lil 6
Dang Yo's Avatar
also make sure you are getting an RPM signal to the fields controller on the controller it will tell you your RPMS if it doesnt then your RPM signal wire isnt connected right so vtec will not engage because it doesnt know what RPM it is at
Dang Yo is offline
S VTEC EF9
04-12-2008 04:44 AM
S VTEC EF9
04-07-2008 05:19 PM
B18aCrIx
04-14-2005 06:09 AM
Quick Reply: NEED HELP W/ FIELDS ON MINIME!!!!
